engine light comes on after 20 miles
Discussion in 'Gen 2 Prius Technical Discussion' started by prius2go, Jan 16, 2008.
  1. prius2go
    prius2go Member
    312
    engine light comes on after 20 miles :(
    and no acceleration only decel
    park up
    switch off
    dank smell of rotting eggs
    start again
    fine for another 20-30 miles
    but engine light on
    diagnostic code says....
    catalytic convertor??
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    What model year is your Prius?
    How many miles on the odometer?
  3. prius2go
    prius2go Member
    312
    do they fail after a number of miles :confused:
  4. nwprius
    nwprius Member
    227
    35
    Perhaps!
    Had you refueled recently? That happened to me once and it turned out to be the gas cap had not been turned on far enough to hear the clicks. The dealer correctly diagnosed the problem. The manual talks about this problem.
  5. firepa63
    1,761
    208
    Catalytic converters will give out after a certain amount of miles, but it's usually in the 6 figure range. Have you added any 'performance enhancers' to your gas when you fueled the car?
  6. prius2go
    prius2go Member
    312
    whats that about Bob?
    yes refuelled - 3/4 tank
    still well in 5 figures :)
  7. Bob64
    1,540
    93
    Virginia
    Bring it into the dealer to have it checked out... it should be covered under warranty... I think. I think hybrid/emission components have a 8 year warranty.
  8. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    federal emissions warranty. head to dealer.
  9. nwprius
    nwprius Member
    227
    35
    Prius2Go
    The gas cap info is in the manual. I am not near my manual at this time. My gas cap event happened after a refueling in New Jersey in '04. In NJ you are not allowed to refuel your own car and I did not check after the service. About 80 miles down the road toward Virginia the check engine light came on. Car functioned OK so drove on to a Dealer. Was told of the improper cap on possibility. Problem solved and afterwards always go at least 2 clicks when installing the cap and check in those states (NJ and OR) when someone else does my service.
  10. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Can't refuel your own car?? What a bummer.[​IMG]
