Engine oil pressure, Not even an idiot light in my 2012 Prius,
Discussion in 'Gen 3 Prius Technical Discussion' started by joematlack, Jul 5, 2012.
  1. joematlack
    joematlack Junior Member
    I sure would like to know the engine oil pressure, can I see this if I hook up a ScanGuage? Does the check engine light come on with low oil pressure and this is your idiot light for oil pressure?
  2. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    That's an odd request, especially for a first post.
    Since Prius establishes oil pressure prior to ignition, a major benefit over traditional vehicles, I don't see how that information would be useful.
    What's the underlining operational detail you'd like to know?
    xyes likes this.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Typically if there is no pressure gauge in a car there in no pressure sender, only a pressure switch so all you would be able to read is switch open or closed.
    This thread
    oil pressure reading | PriusChat
    confirms no pressure sender.
  4. etobia
    etobia Member
    116
    NEW YORK STATE
    I guess I am not sure I understand the need, except that looking at oil pressure is common with gas vehicles. Have you read the manual? Ther may also be functional info in the gps/Bluetooth screen, but it's buried in the options and not readily available. Since you have me fascinated by the question I'd like to see more info about things like oil, coolant, etc. are all of these checked over during the button start phase and then the idiot light on the dash would show up to prompt contacting Toyota?
  5. joematlack
    Why do I like to know the oil pressure?
    Older cars and many sports cars have an oil pressure guage. I have never owned a car without at least a idiot light for oil pressure.
    Oil pressure can be an indication of an overheated engine, it can indicate the general health of the engine. An idiot light if it flashes can warn you that your oil is low as it shloshes away from the pick up tube as you go around a corner.
    I am happy to hear that oil pressure is established before the engine starts, I have always wanted to install a engine pre-lube system to do this on some of my other cars. How does the Prius do this??
    thanks for any additional info.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I don't know the details of how the car knows there is oil pressure before the engine starts, but the MG (Motor Generator) that starts the engine spins the engine much faster than a normal starter motor so it would be quick and easy to do so.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    People would probably freak if the oil-pressure light was on (engine off) half the time in their commute, don't you think?
    alekska and BZzap! like this.
  8. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    If something is wrong the car will let you know. Sometimes, less information is better. Drive the car, don't worry, and enjoy!
    edit: *700th post, I love PRIUSChat!
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The problem is that, as things stand, the car will let you know you will have a catastrophic failure while it is happening.
    How do you know the inverter pump failed? When the dash lights up & most power is lost. If inverter temp were displayed one could see it getting hot & pick a place to stop.
    If you want more instrumentation buy a ScanGauge. Oil pressure is probably the least of your worries.
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Looking at a copy of the '10 Prius manual that someone pieced together into one PDF, there is a warning message LOW ENGINE OIL PRESSURE that can be displayed on the MID in section 5-2 "Steps to take in an emergency". I don't think an idiot light is needed. Check your manual.
    FWIW, I had an oil pressure gauge on my 350z. It wasn't helpful at all. It was pretty high when the engine was cold, went up as you accelerated and was pretty low when idling w/a warm engine. There was a HUGE acceptable range and I recall there even being an acceptable/unacceptable range marked on the gauge itself (e.g. no red area). I'm looking at a PDF copy of the manual and even it doesn't say anything about what's good/bad in terms of needle position.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Loud grinding, thrashing noises followed by silence would be an indication of a catastrophic mechanical failure.
  12. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    The Scanguage won't show oil pressure as there is no pressure sending unit. There IS a switch. It isn't connected to a light per se, as it would come on when the engine stopped at lights etc. It is connected to one of the computers and will trigger a warning message in the appropriate conditions. Be aware most engines running good quality oil will run for quite some time without damage at low oil pressure, at low loads. So a warning isn't as time critical as some think. If you're racing, that's another matter entirely. In that case the engine is at high load most of the time and oil pressure failure, even for a few seconds, can be a "bad thing". The Prius engine is at high load for very short periods and only rarely.
  13. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    You could search this entire forum (all years) for a report of oil pressure loss and engine damage. I've never heard of this happening on a Prius.
  14. Jenpen
    Jenpen Junior Member
    43
    san Antonio
    I would really like more feedback from my car I don't average over 200k miles waiting for an idiot light in the extreme temps I drive in I have been forced to adjust how I drive to keep the engine in the safe range. The car gives great feedback on economy and I am using that but when it is 100+ ac running two kids grocerys slight grade I find my self hoping all is well. Does the scanguage ii give good feedback?
    Sorry for the hyjack
    Jen
  15. David Beale
    5,963
    1,985
    Edmonton Alberta
    You can monitor the engine coolant temp. and other critical items. It really isn't necessary. The Prius will warn you if something is amiss.
  16. Dark_matter_doesn't
    691
    151
    Seattle, WA
    You could install an oil pressure gauge if it was absolutely necessary for your peace-of-mind, but you'd have to get used to seeing zero pressure frequently with the engine off, and having the oil pressure vary wildly with the engine on.
  17. El Dobro
    El Dobro A Member
    7,071
    3,258
    Yep, a buzzer goes off, the triangle of death pops up and a warning message in the instrument cluster says "LOW ENGINE OIL PRESSURE"
  18. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    BTW, if anyone cares, the 2010 Prius manual is single PDF at 2010 Prius Owner's Manual Available on PDF | Page 6 | PriusChat. Toyota ought to put up a copy that's all joined together. Makes it a lot easier to search.
    I think you're right. I don't think I've seen any of that. I can recall some posts where their high mileage Priuses now consume a lot of oil because they or someone else let the oil level run too low.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    What does the above quote mean please?
  20. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I'm not speaking for Jenpen but I have been in situations in other cars where the engine was getting hotter than desirable so adjusted my driving to reduce heating long before an idiot light would come on. By doing that I avoided the need to stop.
    I prefer to do that rather than have to respond to an idiot light that is saying act now to save your engine. By the time an idiot light comes on, your engine is already operating under highly undesirable conditions.
