Engine on Prius I is it the same as Yaris and Echo
Discussion in 'Generation 1 Prius Discussion' started by Shanawany, Apr 3, 2010.
  1. Shanawany
    Shanawany New Member
    jordan
    2003 Prius
    I
    2001 Prius Needs a new Engine.
    We dont have those available, and are Expensive if found.
    Is it the same as Yaris and Echo ?
  2. bwilson4web
    15,934
    Sorry, no. The camshaft and I understand the pistons are different as well as the engine control unit (ECU.) The block is the same but there may be other holes and mounting tabs we don't know about.
    Any more details about the engine problem?
  3. Shanawany
    jordan
    2003 Prius
    I
    Thank you Bob
    As I expected and was waiting for
    Your response was the first.
    I received the 2001 prius with the Biston Rod coming out of the
    Block ( Crank case ). A big window wide open ( 3 inch whole ).
    Engines are rare here and cost an Arm and a Leg.
    This Unit I bought from Insurance Auto Auction.
  4. bwilson4web
    15,934
    Owch!
    The Prius engine uses an Atkinson cycle:
    • partial intake valve open on first of compression stroke - this pushes some of the fuel-air mix back into the intake manifold, reducing the compression ratio.
    • 13 to 1 expansion ratio - upon combustion, the power stroke provides a high expansion ratio to extract energy.
    In theory, the same crankshaft might work but the pistons would be different from the other 1.5L engines. Definitely the intake valve camshaft would be different from an Echo/Scion engine. Then too, the engine controllers would be different since the Prius engine often shuts down.
    We see Prius engine and engine/transmission pairs show up on Ebay from time to time. But getting one exported will be difficult. Yours is the first posting of an engine losing a piston rod through probably the oil pan. Any possibility of photos of the damaged engine?
    Do you have a shop where you could rebuild the engine? Pulling the head and dropping the oil pan would give a better idea of the internal damage. I would expect at a minimum:
    • pistons, piston pins and rods
    • crankshaft
    • new bearings (check case for damage)
    • oil pump (why the rod departed?)
    • valve seats, valves(?), guides e.t.c.
    I rebuilt a 1500 cc VW engine many years ago but that was a primitive engine compared to the Prius engine.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    [ame=http://en.wikipedia.org/wiki/Toyota_NZ_engine]Toyota NZ engine - Wikipedia, the free encyclopedia[/ame]
    Looks like the basic block is the same, but it is clear the head is different. Comparing a parts list would be interesting.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    The block is machined differently to offset the bores of the cylinders to the centre line of the crankshaft.
  7. Shanawany
    jordan
    2003 Prius
    I
    I am shoppng for a new engine locally.
    The car is still in my store at a Free Zone area.
    It will take sometime to clear customes and others.
    Will let you know.
    Thanks.
  8. bwilson4web
    15,934
    Last night, I searched for "prius engine" on Ebay and saw several 2001-03, NHW11 engines. I doubt if the NHW20 engine could be used.
  9. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    i wonder if the NHW20 engine will work, all i could think of a difference is the intake manifold and a/c compressor
  10. bwilson4web
    15,934
    Things to check:
    • engine sensors - everything that feeds to engine ECU
    • engine actuators - check the variable valve control and throttle plate
    • check the coolant line fittings and emissions piping
    • check the transaxle fitting and alignment
    It would be a lot easier if one has both an NHW11 and NHW20 engine side-by-side.
  11. Shanawany
    jordan
    2003 Prius
    I
    apparently, they are not.
    I bought a used Prius I Engine imported from Japan.
    I wa surprised to know that the dismantler could not use the Transaxle, it was taken from RHD car. unless the whole herness was changed.
    we started the car. but it only ran for few seconds and we had P3101 code.
    We cleaned the throttle. but it id not work.
    Will continue tomorrwo.
    will check the 12V Batt' and check the fuel.
    We used semi synthetitic Oil. !!!!!
  12. Patrick Wong
    18,200
    6,490
    DTC P3101 is produced by the hybrid vehicle ECU. This is saying that either the engine did not start or is producing low output. Usually this would be accompanied by the engine ECU producing DTC P3191.
    I suggest you check fuel line pressure, which should be at least 43 psi. If not, check the resistance across the circuit opening relay switched contacts when the relay coil is energized with 12VDC. The fuel pump is located within the fuel tank.
    Check the iridium spark plugs, the correct gap is 1 to 1.1 mm (replace if the gap is too large, do not try to adjust the gap on worn plugs.) See if you have a spark by removing one plug at a time, reattaching the igniter to the plug, connecting the wiring harness connector to the igniter, grounding the plug shell, and then have someone try to start the car while you look at the plug to see if it is sparking.
    Be careful of the high voltage. Do you smell unburned fuel being injected into the cylinder where the spark plug was removed?
    Is the throttle plate and throttle body interior clean, so that you can see shiny metal? Clean the mass air flow sensor using MAF cleaner.
    If you have the ability to perform a cylinder leakdown test, then you can assess the condition of the replacement engine's valves and piston rings.
    If you have fuel and spark, the MAF and throttle are clean, and you think the engine is mechanically sound, then you may have to replace the engine ECU. Do a search for TSB EG011-03, which I've previously posted. Good luck.
  13. jk450
    jk450 New Member
    That TSB was rendered obsolete by T-SB-0180-09 last June.
