Engine RPM @ 70 MPH
Discussion in 'Gen 3 Prius Technical Discussion' started by Bill075, Oct 7, 2009.
  1. Bill075
    Bill075 Junior Member
    22
    Central Indiana
    Does anyone know how many rpm's the engine is running @ 70 mph.
    Sure do miss a tach.
    Thanks
  2. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Bill,
    It depends.
    With a CVT (continuously variable transmission), factors such as engine load, vehicle load and terrain will affect engine revs. With cruise set, engine revs will climb when driving up a hill and drop when driving down a hill as the transmission seeks out the correct ratio for the circumstances.
  3. Bill075
    22
    Central Indiana
    Thanks for the reply, sure are a bunch of variables. :)
    Ok just a round about figure on a flat road, sunny day, no wind, 400 lbs of total added weight.
    I know the cvt wants to keep the engine in the sweet spot.
    Just curious.
    -Bill
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    Following is a copy of my post.
    The Japanese sales staff manual says following data at 120km/h(74.6MPH).
    item 2G 3G
    1 engine RPM 2 470rpm 2 180rpm
    2 MPG 40.5MPG 44.7MPG
    Please note that higher speed always worsen your mileage at highway.
    Ken@Japan
    4 people like this.
  5. Bill075
    22
    Central Indiana
    Thanks Ken@Japan, thats what I wanted to know.
    Couldn't find that nfo when I did a search.
  6. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    If you are curious how much it can vary, you can use this simulator. 114 km/h is about 70 MPH
    A simulation of Prius's Planetary Gear
    In theory, it can be anywhere from idle. (1000 RPM) to redline (5000 RPM)
  7. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    I just bought a ScangaugeII (I, too, miss a tach) and I guess I can understand why a tach wasn't included in the MFD. Even at a steady/high speed, the rpms are all over the place. And, especially coming from a type-S RSX, they are *way* low. Amazing to see the slightest downhill drop the engine speed to ~ 900 rpm even at 70+. Generally (anecdotally), it seems to run about 1800-2500 at highway speeds.
    Gotta keep those eyes on the road...
    T
    btw the scangauge is cool ;)
  8. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    That simulator's speed display is for Gen 2. Gen 3 has a different final drive ratio so the speeds are different.
    The key point is that the combination of motor and engine torque has to balance the current road demand, with just enough power being produced to keep the electronics running (base load: 300-400W). Otherwise the battery will be slightly charging or discharging. In practice this means the engine has to run a lot faster than the limitations of that simulator would suggest. For a road speed of 113km/h (about 70mph) the simulator says MG1 can be running backwards at 6,500rpm and the engine at 1,150rpm, but in fact the engine can only achieve about 10kW down there, and just to overcome wind resistance requires about 15kW. My guess was that total losses are approaching 20kW; the power curve suggests that Gen 2 would be producing about 25kW at the engine speed that Ken indicated.
  9. bwilson4web
    15,932
    After adjusting for the temperature, 82-86F / 28-30C, there is good agreement:
    Warmer temperatures make the air thinner and reduces aerodynamic drag. You'll notice the 80 mph / 124 kph test at 62F/16C had a significant drop.
  10. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    Not sure about my Prius, but my 1988 VW Cabriolet runs at about 3500 RPM at 70 MPH.
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    You can order a ScanGaugeII for $170.
    ScanGaugeII - Scan Tool + Digital Gauges + Trip Computers
    It will display 4 parameters at a time. I have the tach and coolant temp all the time, presently displaying ignition timing and throttle position for the other 2.
    Easy to mount and set up. They had them in the PC Shop for $160 a while back but they are no longer listed.
  12. fuzzy1
    10,332
    Still listed as $159.95 non-member price at CleanMPG.com. $149.95 member price. No one should pay the non-member price, but the member deal has to be 'slightly' disguised, so be sure to read the hints or the 'fund raiser'.
    Amazon.com has occasional deals $10 cheaper, for those with plenty of patience to wait for the next offering.
  13. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    my caddy used to run about 1800 rpm at 75 -hahahaha
