Engine "Run-on"
Discussion in 'Gen 2 Prius Technical Discussion' started by splendid, Feb 12, 2010.
  1. splendid
    splendid Junior Member
    22
    Orlando FL
    I have noticed now several times that when the ICE would normally switch OFF during its normal operation (such as when braking, moving slow etc) it will "run-on" for a few seconds. It may do this more when it is cold than warmed up. I assume this is not normal.
    Any ideas of what this could be caused by?
    I hesitate to call the dealer about it now knowing they are so busy with the recalls.
    Thanks!
  2. Bob64
    1,540
    93
    Virginia
    Long answer: Look for the 4 stages of prius operation in this forum. Your probably not in stage 4.
    short answer: your engine isn't warm enough.
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    splendid,
    More than likely, short periods of "run on" are normal.
    I can think of three situations when it is typical:
    * The ICE, Internal Combustion Engine, is running to warm up
    itself and/or the catalytic converter.
    * The ICE is turning MG1, Motor/Generator1, as a generator to bring
    the SOC, State of Charge, of the High Voltage/Traction battery up to
    the level that the HSD, Hybrid Synergy Drive, computers try to
    achieve/keep in cold weather.
    * The HSD is rotating and slowing the ICE so that it can be stopped in
    EXACTLY the right location so that it can be restarted most easily and
    with the minimum jerking or stuttering.
    The SOC level noted above is somewhat higher than in warm weather.
    It has been speculated that as getting and maintaining this level
    requires that more electricity flow into and out of the HV battery, it's
    purpose is to warm up the HV battery due heat generated by the
    reversible chemical to electrical conversion process in the battery.
    As long as you aren't seeing any warning lights, hearing any horrible
    noises, or feeling any really extreme shudders, etc on restart, I'd say
    there's nothing to worry about.
    I hope this helps.
  4. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    If you mean very brief turning over of the engine, it is normal. The engine will attempt to stop at a specific crankshaft angle. When cold, and/or when the oil is too thick (ie not 5W30) it will sometimes fail, and will retry until successful. It sounds like run-on, but it isn't. The engine is being spun by MG1, not burning fuel and sputtering.
    -Usually- this behavior will stop once you get a year or two of use on the car. But apparently, not always.
