Engine sputter/stutter
Discussion in 'Gen 2 Prius Main Forum' started by egullsfan, Sep 29, 2008.
  1. egullsfan
    egullsfan New Member
    Sacramento, CA
    I drove on a field trip (I teach 4th grade) and the trip was 70 miles one way. It was about 90 degrees that day, and the elevation change is about 2000 feet over the 70 miles. I had 5 people in the car, 2 adults and 3 nine-year olds. The trip there was fine. I got right around 50 mpg with the AC on. 4 hours later, we go to leave. There is a steep uphill grade out of the state park, a one lane road where I could only go about 20 mph. I noticed the car seemed to be revving really high, and seemed to labor up the hill. As I crest the hill, the RPM's seem to stay the same, yet the car would not go any faster. I slow down to about 5mph, then start to go again. When I press on the gas, the car stutters(like I had an arching spark plug wire and was running on 3 cylinders). I couldn't get the car over 30 mph and that was a struggle. The battery monitor showed green, even after the hill (it was full green when I turned it off 4 hours earlier). The car continued to sputter every time I would press on the gas, but I could get it to stay at a fairly consistent 30 mph with even gas pedal pressure. After about 5 minutes, the sputtering stopped and the car seemed fine. The only weird thing I noticed was that the battery monitor stayed in the exact same position (didn't discharge or recharge), a little over half a charge, even though I was using and recharging the battery often in the next 10 minutes. By the time I got back to Sacramento, all was fine and I was still getting around 50 mpg still.
    The only thing I can think is that one of the students was leaning over on the battery air vent on the back passenger side of the car. Did the battery overheat??? Any help would be appreciated. The car has been fine ever since.
  2. removeum
    removeum Member
    407
    El Paso, TX
    :cool:It is possible that the batteries were overheating. However, did you hear the fan come on and if you did not then the batteries did not become hot. You can always take it to dealer and ask them to check and see if it throwout a code that could be located by a scan tool.
  3. Bob64
    1,540
    93
    Virginia
    Was this at a "high altitude" location?
  4. daniel
    14,487
    1,519
    Spokane, WA
    An overheated battery should not cause engine stutter. When the battery gets too hot the car will reduce its use of it, and mpg will suffer slightly as a result, but that will not affect how smoothly the engine operates.
    The engine will rev high on hard uphills, and that is normal. Because of the unique power train, the engine can run fast when the car is going slow. This provides electricity to MG2 via MG1 acting as a generator, providing a lot more torque than a conventional car would get at slow engine speeds. But you will be able to go normal highway speeds.
    What you describe, the stutter, and the real lack of power, sounds like an engine problem.
  5. dogfriend
    7,512
    1,188
    Carmichael, CA
    The OP stated that the elevation change was about 2000 ft; Sacramento is not much higher than sea level, so the max elevation was about 2000 ft.
    My dad used to live between Placerville and Camino (elev ~2600 ft); I have not experienced what the OP described driving up to Placerville or even at higher elevations (Lyons Creek Trailhead and Echo Summit > 7200 ft)
    I have noticed that use of the AC in stop and go (or stopped) traffic conditions can run the HV battery down pretty quickly. When the battery gets depleted (purple bars on the MFD), the car will protect from further discharge and will rely more on the ICE with higher ICE speeds and lack of torque from MG2. I wonder if this was the cause of the problem?
  6. egullsfan
    Sacramento, CA
    It wasn't real high altitude driving, maybe 2000 feet above sea level. I'll check to see if it threw any codes. It is just so weird, it drives fine now.
  7. richard schumacher
    7,664
    1,042
    United States
    Any chance you were in "B" and not "D"?
  8. AbuLafya
    AbuLafya New Member
    San Jose, CA
    I had these same symptoms more than once.
    It only happened in relatively high altitude (Lake Tahoe area), when temps were not cold.
    What I think happens is that the smart powertrain system gets confused. It only happens in very slow speeds, i.e. starting from 0 and speed < 10 MPH.
    Since the gas pedal is "drive by wire" the gas engine revvs for less than a second and then incorrectly revvs down. The car barely manages to climb the grade and the driver presses the pedal harder, which does not do anything. Releasing the pedal and trying again more "gently" produces some result but barely making any progress.
    After the grade is over, or speed increases, everything is back to normal.
    Is there a "software update" we can get?
  9. Moving Right Along
    Moving Right Along Senior Member
    699
    546
    Bumping this thread because it sounds similar to what I noticed with my car recently, although probably not for the same reason. I’ve noticed a couple times within the last month or so that when the temperature gets below zero Farenheit and I open up the throttle, the engine revs then stops then revs then stops, and repeats that way for a few seconds while the image on the multifunction display shows power alternating from the engine to the battery (which is at normal 6 bar charge level). I’ve never noticed that before despite living in Minnesota where it gets cold every winter. It will eventually get back to normal after maybe 10-15 seconds but it’s somewhat disconcerting when it happens. Any ideas?
  10. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Third planet from the Sun
    Inspect the throttle valve. In cold weather, it may contain more traces of oil escaping from engine systems.
    The second reason may be fuel with a small water content. Ice crystals clog the filter and fuel supply becomes uneven.
    In general, diagnostics of the fuel system, air supply and engine ignition system are necessary.
