entry illumination problem
Discussion in 'Gen 2 Prius Main Forum' started by ghawkins99, Aug 6, 2009.
  1. ghawkins99
    ghawkins99 New Member
    broken arrow, ok
    My entry illumination quit working on my 09
    a few days after the same thing on my 08.
    Could I somehow deactivated it?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    clarify... are you talking about the smart key function.. where the interior lights come on as you approach? are you referring to the puddle lights at the bottom of the doors? (that would be really odd)
    if your key fobs batteries are low, or a cell phone is in the same pocket, the smart entry light may not come on until the doors unlock. the car may not start right away either (with a cell in the same pocket)
  3. Tideland Prius
    16,406
    could you be more specific? What's isn't working? (and what did it use to do?) That way, we can narrow down to the part that's malfunctioning.
  4. ghawkins99
    broken arrow, ok
    It is the set of interior lights that come on when you near the car
  5. ghawkins99
    broken arrow, ok
    The interior lights that come on when you near the car:)
  6. Tideland Prius
    16,406
    Hmm... ok here's a few questions I need to ask to narrow down the problem even further
    1. Does your Smart Key function work?
    2. Do the lights come on when you open the door?
    3. Is the Smart Key always in the same pocket as before? Did you add anything new to the pocket (specifically anything metallic like other keys or a cellphone)
  7. V8Cobrakid
    3,790
    152
    get new batteries for your keyfobs... as this really does seem like the problem... lights not turning on as you approach means the car isn't reading your signal from as far away.. and is waiting because you apparently have to be right next to the car for the key to work. sooner or later, you'll realize it doesn't work at all. at that point you'll use metal key to unlock and keyfob in the dash to start (like i do because my keybob needs a new battery)
