Error code b1412 ambient temperature sensor circut
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq86, Dec 18, 2015.
  1. Tariq86
    Tariq86 Junior Member
    Jordan
    Hello all
    My Prius 2010 outer temperature displays dashes, like this --
    Is the problem with the sensor? and has anyone had such a problem?
    Thank you
  2. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Easy to visually check the sensor. It's attached to the vertical bar under the hood latch behind the lower grill. Check the cable and connector.
    Tariq86 likes this.
  3. Tariq86
    Jordan
    Thank you for your quick reply and explanation. I will and hopefully it works.
    One last thing please, Can I reach the sensor or do I have to remove the front bumper?
  4. David Beale
    5,963
    1,987
    Edmonton Alberta
    If you have skinny hands/arms, maybe. But front grill removal is probably the norm. Log into the US Toyota site and pay the small fee to allow you to download the service manual. It should list the required procedure in its many pages.
    Tariq86 likes this.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    There is a plastic cover over the top of the radiator. Just remove this cover and you can see and get to the sensor.
    Tariq86 likes this.
  6. Tariq86
    Jordan
    Great! Thank you, brother David Beale. That was so helpful.
  7. Tariq86
    Jordan
    Thank you for this info. So easy
  8. David Beale
    5,963
    1,987
    Edmonton Alberta
    Well, it's still very tight. I installed aluminum mesh behind the upper and lower grill. I did remove the plastic cover. I could not get my arms down more than about 15 cm. I'm a pretty big guy, with strong forearms, so that probably had a big effect. But give it a try. No cost to try. I found it very difficult to access from below, so from above is the way.
    Tariq86 likes this.
  9. Tariq86
    Jordan
    I'm a skinny mini, so I will give it a try for sure.
    I appreciate your help. Thank you again
