ERROR! Major MALFUNCTION!
Discussion in 'Gen 2 Prius Main Forum' started by DrPhlox, Jun 21, 2006.
  1. DrPhlox
    DrPhlox New Member
    Unfortunately, there is not a "frowny" large enough for how I'm feeling right now.
    My car had a major malfunction today (a 2004 pkg #9 Silver; ONLY 22k miles!). While driving thru Palo Alto, the engine started to sound like a lawn mower and ALL (and I do mean _all_) of the warning lights came on (all across the dashboard and the MFD). The brakes went out, (I had to _really_ stomp on them to slow the car down), and I could go a whole _8_ miles an hour! (whee!). So, needless to say, I pulled over and called the Toyota dealer (in my case: Toyota 101 in RWC). They said that "they've never encountered this before" (where have I heard that before??), but to "bring it in immediately". Well, I *did* try, but at 8 mph, that car was like driving a brick on jello (really!). So, I pulled over and got a tow truck to take it (and me) in to the shop. Now, here I sit with a rental, waiting for news of what will happen.
    As far as I can tell, (and I don't know much, really!), the hybrid system TOTALLY failed on me. I might be pretty pessimistic at this point, but it seems like the only good thing going for me is that it's still under warranty (this is a test of the Toyota warranty...).
    One little question for the masses: Has anyone had this sort of problem [yet]? If so, how was Toyota in dealing with the problem/warranty?
    Thanks for any and all info!
    -= Dave =-
  2. Kev1000000
    Kev1000000 New Member
    271
    Livonia, MI
    did you happen to be on the freeway?
  3. rufaro
    rufaro WeePoo, Gen II
    2,867
    72
    Lost Angeles
    <div class='quotetop'>QUOTE(DrPhlox @ Jun 20 2006, 09:45 PM) [snapback]274509[/snapback]</div>
    OUCH!
    And how 'bout this: <div align="center">[​IMG]</div>
  4. ghostofjk
    ghostofjk New Member
    979
    Unless something really unusual happened to the ICE (e.g., running out of oil), which is unlikely (unless something freaky happened like getting an oil change and someone forgetting to put the drain plug back in), it is probably a software problem.
    Let us know!
  5. jamarimutt
    jamarimutt New Member
    985
    My car had a somewhat similar power failure a while ago. The red triangle came on, as well as the brake light, and although the ICE still worked, it only powered the car through the electric motor, as when you drive in reverse with a low battery. The problem fixed itself after restarting the car and a couple of weeks later I took it to the dealer for the ECM upgrade (I had received the recall letter a long time ago but had paid little attention to it).
    The original problem has not repeated itself, but now the car sometimes shifts into neutral, immediately after starting it, and some lights come on (see photo). When this happens the only solution is to remove my foot from the brake so the car moves slightly and shifts back to park.
    I still like the car, but enthusiasm has decreased a bit. ;)
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Sure you weren't out of gas? The ICE noise seems to go against the out of gas condition diagnosis, but who knows.
    Have you had all the SSCs performed (50J in particular)?
  7. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Oh man, DrPhlox, that sounds bad.
    I have an '04 #9 with 20,900 miles and I'm definately staying the Hell away from Palo Alto!
  8. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    you absolutely sure the lawnmower noise was coming from the engine? was the car running on electric then after all the lights came on? or was the engine still trying?
    heard of problems with the VSC steering angle sensor that won't let you go more than a couple miles an hour, but that doesn't seem to cover everything else.
    well, i'll ask DH about it tonight and see what he can come up with.
    sorry your car is having trouble :(
  9. Mirza
    Mirza New Member
    898
  10. Jim1eye
    Jim1eye Shaklee Ind Distributor
    181
    Connecticut
    2022 Prius Prime
    <div class='quotetop'>QUOTE(DrPhlox @ Jun 21 2006, 12:45 AM) [snapback]274509[/snapback]</div>
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Jun 21 2006, 09:02 AM) [snapback]274593[/snapback]</div>
    What amazes me is that you guys have '04s with 20,000 miles on them. Locutus is 8 months old and rapidly approaching that.
    Good Luck, Dave. Please keep us posted.
  11. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    ouch. Sounds like the hybrid version of the blue screen of death. :p Is there a system reset function? (hopefully it is not a button on the bottom of the car) So far the only problem I have had is my car will not respond after I turn it on (will not go into gear, turn off, etc). I think it has to do with the radar testing here.
  12. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    Any updates for us?
  13. galaxee
    9,810
    468
    MD
    well, with that major of an issue, he won't even begin to speculate without the car in front of him to test it himself.
    example: what is "sounds like a lawnmower?" could be misfiring, could be a damper, could be a spring, exhaust ripped off by large chunk of debris on highway, etc.
    over the internet there's only so much you can do and this isn't something common where he can just say "oh it's problem X, here's what they'll do"
    once they get some diagnostic info from the car, post it and we'll have more to go on. for now, it's a very wide range of possibilities.
  14. DrPhlox
    DrPhlox New Member
    <div class='quotetop'>QUOTE(galaxee @ Jun 21 2006, 06:55 PM) [snapback]274950[/snapback]</div>
    Too bad I didn't have my camera with me! (I could have even _recorded_ it! And I usually *do* have the thing with me! Oh well, let's hope there's NOT a next time!).
    Anyway, I heard back from Toyota 101 today, and they tell me that my inverter went south, (this might explain a lot). I won't get it back until [at least] Friday (upon which I will get/post the codes here, too). They are ordering the part, put it in on Thursday and have to "road test it cold" on Friday AM. To top it off, there was some kind of recall (I haven't been keeping up w/all the news, unfortunately), so it's getting all of that done to it, as well.
    I'm hoping my little car comes back as happy as I got it... I'll let you know of all of the codes when I get them, (they *will* be on the maintenance bill, right?).
    -= Dave =-
  15. DrPhlox
    DrPhlox New Member
    <div class='quotetop'>QUOTE(DrPhlox @ Jun 22 2006, 12:33 AM) [snapback]275114[/snapback]</div>
    As an FYI, I found a link to a forum for "Prius Software Problems" wherein someone describes a similar situation to mine (although, I wasn't trying to get on the freeway):
    http://townhall-talk.edmunds.com/WebX?14@@.ef64fbc/62
    -= Dave =-
  16. ghostofjk
    979
    I think yours is the 2nd or 3rd inverter failure reported here.
  17. richard schumacher
    7,664
    1,042
    United States
    Idle question: did you ever wash or steamclean the drive compartment?
  18. galaxee
    9,810
    468
    MD
    <div class='quotetop'>QUOTE(DrPhlox @ Jun 22 2006, 01:53 AM) [snapback]275122[/snapback]</div>
    most of those are describing the SSC 50P recall- a software update, basically.
    there is a new recall out on a steering part that has caused no problems to date, but they're changing them out for safety. otherwise they may be talking about the SSC 50P i mentioned.
    the inverter...? sounds funky to DH, but if it's under warranty the cost isn't coming from your pocket... if it wasn't under warranty this would be another story... anyway let us know what happens.
  19. Frank Hudon
    Frank Hudon Senior Member
    4,147
    there were some of the 2004 inverters that had coolant leaks into the electonics that shut the car down. Probably what this is. There was a service bulletin on it. Can't find the number now.
  20. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
    <div class='quotetop'>QUOTE(Frank Hudon @ Jun 22 2006, 02:28 PM) [snapback]275450[/snapback]</div>
    Aha! EG017-05. See 'em all in the files section of the yahoo toyota-prius-sat1 group, courtesy of MRV.
