Euro Mudguard install question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dropshot, Feb 5, 2011.
  1. dropshot
    dropshot New Member
    28
    I received my Euro mudguard and ScangaugeII today from PriusShop.com. Thanks, Danny!
    I've got a question about this black trim piece on the wheel wheel edge. It looks the same as the door edge guards on the doors that I am 99% sure are not intended to be permanent. They are not in the way on the rear wheel well but they are on the front wheel wells. Do I remove or at least trim these?
    Front
    Rear
    Please excuse the dirt, the snow in Texas wasn't too clean. :rolleyes: I will wash the car before I install them. ;)
    Thanks!
  2. dropshot
    dropshot New Member
    28
    OK I removed the trim on the front wheel wells, came off clean and easy.
    The rears fit nice, the fronts have some gaps I couldn't eliminate that you can see in the photo because the fronts used the existing bolts and push fastener so there is no way to adjust them. The rears required drilling a small pilot hole in the plastic for all three screws.
    Front
    Rear
    They look good on the Blue Ribbon Metallic :cool:
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes they do look good, good job. I would have trimmed the trim piece myself but my car didn't come with those.
  4. Tideland Prius
    16,403
    Looks good! Yeah I have noticed that the front one isn't secured as tightly as I like. There's too much play in the bottom half of the mudguard.
  5. unkprius
    unkprius Member
    152
    The smaller version mudflaps also don't fit 'tight', with a gap here and there that let them wiggle a bit. The whole area is all plastic and isn't a model of perfect fitting, if it were metal all the tolerances and fit might be a bit better, but then we wouldn't want to drill holes in it.
  6. Tideland Prius
    16,403
    Our OEM mudguards on our 2005 (they are standard equipment on all Canadian Gen 2 models) are screwed it front and back so they're quite solid/rigid with no wiggle room.
  7. Les Gas
    Les Gas New Member
    U.S.A East Coast
    I just installed the same mad guards on a 2010.
    Poor fit is caused by the plastic mould for the top screw. That area jutts out toward the fender causing a gap. The push retainer in the kit is useless IMO. I ended up using the OEM female side of the reatainer and a screw. No more wiggle.
    BUT. The little gap invites water/salt/etc to settle inside. I think a little bead of black silicone smoothed over with fix it up.
  8. wernolabound
    wernolabound Junior Member
    40
    Miami, FL
    Generally are you happy with the resulting product? I should get mine today.
  9. Les Gas
    Les Gas New Member
    U.S.A East Coast
    Yes I am happy with them. They look like they belong there and are solid. Makes the car look more sporty and should provide good protection behind the wheels.
