EV and MPG reset
Discussion in 'Gen 2 Prius Technical Discussion' started by grasshopper, Feb 17, 2007.
  1. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    I have had a Coastal EV switch installed (this is the one that is activated by pulling on the cruse control lever) on my 06 #3 for about 17,000 miles. A far as I can determine, my MPG readout has not reset when filling up since it was installed. Don’t get me wrong, I like that it doesn’t reset because as long as I don’t reset it, my readout is average for the life of the car. I am wondering if anyone else has noticed this with there Prius? Except for intermittent response in the winter, the EV switch has been working just as one would expect. Just curious!
    By the way, don’t touch your screen because I have a terrible cold and wouldn’t want you to catch it.
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(grasshopper @ Feb 17 2007, 03:21 PM) [snapback]392078[/snapback]</div>
    The situation you describe is normal. The mpg displayed is cumulative until it is either reset manually or the power is cut.
  3. slvr_phoenix
    slvr_phoenix Tinker Gnome
    84
    <div class='quotetop'>QUOTE(JimN @ Feb 17 2007, 10:41 PM) [snapback]392240[/snapback]</div>
    That's exactly what my '06 does. The average MPG only resets when you manually reset it. However the number of miles next to that average MPG resets every freaking time I get gas. It's very annoying actually. I really wish that would also only reset when I hit the button to manually reset it.
  4. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    <div class='quotetop'>QUOTE(Silver Phoenix @ Feb 20 2007, 07:17 AM) [snapback]393264[/snapback]</div>
    The car has two trip odometers that don't reset until you reset them. Just forget about the MFD mileage, and use one of the trip odos if it bugs you to have the MFD odo changing.
  5. slvr_phoenix
    84
    <div class='quotetop'>QUOTE(subarutoo @ Feb 22 2007, 02:43 PM) [snapback]394761[/snapback]</div>
    Would if I could, but I can't, so I won't. I already use my trip odometers for other purposes. If I could, I'd add a Trip C. But it'd also be exceptionally handy (and rather expected behavior) if the average MPG/milage settings only reset when you press the button to reset them. If that's not an actual software bug, it's most certainly a GUI blooper.
  6. danatt
    danatt New Member
    145
    Connecticut
    Yeah. This one had me a bit puzzled for a while. I had just assumed that the mileage and the MPG readings on the MFD corresponded to each other, since they both sit there side by side, and since they both reset when you hit the reset button. But then you fill up a tank and one resets but the other doesn't. :blink:
    One demerit for the guy who did the code on that one.
  7. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(danatt @ Feb 24 2007, 05:23 PM) [snapback]395955[/snapback]</div>
    I'd give him/her two demerits. They had it working in 2004 and 2005 (both reset). They still say they both reset in the 2006 manual and I surmise they have not fixed either the car or the manual for 2007.
    - Tom
  8. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Yeah, anytime you add five gallons (or was it 4?) of gas, the miles on the MFD will reset, but the MPG will only reset if you push the reset button. As stated above, there are two trip Odo.... to use to calaulate whatever you want to measure...... :D
  9. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Rangerdavid @ Feb 25 2007, 08:39 AM) [snapback]396216[/snapback]</div>
    In the 04 and 05 models, both the miles and MPG automatically reset in these circumstances.
