For Sale EV Peak CQ3 50Wx4 6A 4 Channel Balance Charger/Discharger & 5 in 1 Cell Meter
Discussion in 'Private Sales' started by CTDEXP, Oct 20, 2020.
  1. CTDEXP
    CTDEXP New Member
    Monroe, GA
    50Wx4 5A 4 Channel RC Battery Balance Charger Discharger
    125 Shipped in the Lower 48
    Take Zelle, Google, Apple etc...
    Hardly used, reconditioned two
    battery's
    Every thing is there.
    SPECIFICATIONS:
    • AC Input: 110V-220V; DC Input: 11-18.0V
    • Charge Power: 50Wx4; Charge Current: 0.1~6.0A
    • Discharge: 5W/2A
    • Balance Curent: 400mA/Cell
    • LiXX Battery: 1-6 S
    • NiXX Battery: 1-15 Cells
    • Pb Battery : 2-24V
    • Digital Power: 3-24V
    PACKAGE INCLUDED:
    • 1x Balance Charger
    • 1x AC Power Cord (US)
    • 1x Banana Connector Male to XT60 Connector Male as DC Power Cord
    • 4x Banana Connector Male to T Plug Male
    • 4x 2S-6S JST_XH Balance Adapter Board
    Also throw in the 5 in 1 Battery Cell Meter
    Comes with instructions.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    You had my attention with the CQ3 in the title, but thought I'd mention your pictures show a CQ2 model, which has a 5 watt discharge limit. A CQ3 has a 10 watt limit, which cuts the discharge time in half..
  3. CTDEXP
    CTDEXP New Member
    Monroe, GA
    You are correct, it is the CQ2 version. I will fix the ad...Thank you.
    OK, I am trying to edit the thread, but the edit button is missing....
    2GenPrius likes this.
  4. 2GenPrius
    2GenPrius Member
    178
    33
    22
    Californication
    And how awesome is the CQ3 vs. Hitec x4?
  5. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Before we semi-hijack this thread, I want to say this:
    The CQ2, I believe, is on par with the HiTec x4 AC+ model 44167. Both are capable of 5w power dissipation. This is perfectly adequate for the average DIY person who's looking to cycle their modules.
    I have (3) of the 44167 models and used them for a while for cycling modules. For someone doing volume, the 5w discharge limit slows things considerably. Jumping to the CQ3 (I have 7 of the CQ3s) or the later 10w model of the HiTec cuts serious time off the cycling. I now keep the HiTec 44167s on standby for other projects.
    Now, there are advantages and disadvantages to both.
    Both are very programmable for safety limits, current setpoints, mAh charged, time limits, etc.
    I love the firmware on the 44167. I can set them to do up to 5 cycles with no further action from me. Regardless of what limit triggers the charge or discharge to stop, it will perform the programmed delay and then start the next cycle. It's just the 5w limit that kills me.
    The CQ3 paperwork says it will do the same, but it doesn't. If it reaches the mAh limit, it will, but for any other limit, it just stops. This is true on all 7 that I own. I have mine set to do only 1 cycle, as I do 28 modules at a time, and I want them all to be on the same schedule. I start one cycle at 530am and one cycle at 530pm. I do not know if the CQ2 has the same firmware 'glitch'. Maybe the OP can fill in that info.
    The new Hitec model that replaced the 44167 features the 10w limit and I've thought about trying it, but I heard it suffers from some firmware glitches also.
  6. 2GenPrius
    2GenPrius Member
    178
    33
    22
    Californication
    Thank you. I'll send you a PM when they start working again.
