EVSE not working
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by gregogarrison, Aug 9, 2013.
  1. gregogarrison
    gregogarrison New Member
    2013 Prius Plug-in
    Just started having a problem with the evse. I plug it into the outlet the connect to the car. The charge indicator lights up but 15 seconds later you can hear the charger click off. The light on the charger stays amber and not red. I've reset the charging unit and it is happening both at the outlets at work and at home.
    Anyone else experience this or know how to correct it.
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Can you get access to another charger to check if it's the charger or the car ????
  3. bvoyles
    bvoyles Junior Member
    22
    San Diego
    Make sure the charge timer in the vehicle is not turned on. If it's on then the charge unit will come on for about 10 or so seconds then shut off and wait until it gets the message from the car to start the charge.
    lensovet, Ken Blake and wjtracy like this.
  4. gregogarrison
    2013 Prius Plug-in
    DOH!!! Yep the charge timer was pushed. Shows you how long I've had the car...
    Thanks bvoyles
    Ken Blake likes this.
  5. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    There's a tell-tale green light at the far right of the instrument panel that will flash when the ignition is off to let you know the timer is set.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Don't feel bad, I think we all have done that at least once! If not more.:whistle:
  7. El Dobro
    El Dobro A Member
    7,071
    3,258
    Not me, I never use the timer. :D
    lensovet likes this.
  8. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    I just did it last week! Luckily I have a level 2 charger in the garage, so little harm was done. ;-)
    markabele likes this.
