Excessive White Particle Dust in Cabin. What is it?
Discussion in 'Gen 2 Prius Technical Discussion' started by LIPrius, Feb 24, 2010.
  1. LIPrius
    LIPrius New Member
    Miller Place
    Please help or comment if you have any knowledge on this subject. My 2007 Prius purchased new from the dealer emits massive amounts of white particle dust all over the interior cabin dashboard, steering column, navigation/ radio area and the window operation controls on both the driver and passenger side of the car. This white particle dust cannot be seen coming into the cabin but is evident by its remains left all over my interior. Clean the car it comes back the next day and by day 3 there is an overwhelming amount of white particle flakes. I am breathing these foreign particles in. What is it? I took the car to Toyota maybe 4-5 months ago. Service couldn't have been better. They pulled the car apart for a week but have no information as to what and where these particles are coming from. I took the car back to Toyota again this morning for another look. They gave me a 2010 Prius as a loaner. The dust is all over that model too! I am now looking for a lab who can test these particles. I greatly appreciate any input anyone may have on this subject. Perhaps someone knows what it is. Many Thanks.
    silver3521 likes this.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I'm not sure what it is, but I'd recommend not trying to cross the border into Mexico or Canada until you get it cleaned up.
    It's not "Scarface" Blizzard Pearl is it?
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Anthrax! Call the Postal Service immediately!
    _H*
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Could they have given you a DeLorean by mistake?
    That's really odd. Especially odd that the Techs couldn't figure out where it came from. It's one thing to say that they located the source but aren't sure what it is but to say that they can't even locate the source is weird.
    Is there any variation between fresh air and recycled internal air? Does it matter if the heat or cooling is turned on?
  5. LIPrius
    LIPrius New Member
    Miller Place
    Thank you for your comment. I don't always use the heating and cooling. Do you have dust particle flakes in your prius?
  6. LIPrius
    LIPrius New Member
    Miller Place
    too funny :)
  7. LIPrius
    LIPrius New Member
    Miller Place
    LMAO. But I really do think I have a problem here.
  8. nwprius
    nwprius Member
    227
    35
    Have you taken out the cabin air filter to check if it is shedding particles. Perhaps leave it out for a few days to see if this could be the cause.
    2 people like this.
  9. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The cabin plastic is a dust magnet. Both my 04 and 09 had/have the problem. It's the same in any car, it just seems more attracted to the plastic dash in the Prius.
  10. richard schumacher
    7,664
    1,042
    United States
    Geez, one would *hope* that a dealer would be smart enough to start with the cabin air filter, but there are no guarantees...
    Since a second car from the same dealer had the same symptom perhaps something in their shop or lot is the source of the material. I'd suggest inspecting and/or changing the cabin air filter yourself, then drive it for a few weeks on recirculate only and see what happens. Carry a Swiffer and sweep up any dust as soon as you see it.
    (On 2nd reading this doesn't sound a lot different than my experience living in a big city. If I don't Swiffer it up, after three days of driving there's obvious dust on every dark surface.)
  11. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Head and shoulders will fix it. :)
  12. jimtompkins
    jimtompkins New Member
    Va
    In my opinion the white powder is aluminum oxide. It is caused by oxidation of the air conditioner evaporator core. The powder should stop when the weather warms and you use your air conditioner. The issue is unaffected by the cabin air filter.
  13. ronbet
    ronbet Junior Member
    Lynchburg, Va.
    I too have this "white dust" issue with my 2008 Prius. I clean and wipe down the dash and other inside components and in a couple of days it re-appears. I have changed and vacuumed the cabin air filter but that doesn't stop dust. Next time I may change the cabin air filter to the charcoal type and see if that fixes the problem. With our Prius luck lately I'll probably end up with charcoal dust everywhere. LOL!! By-the-way, 22,400+ miles on this 2008 model and none of the issues we have been hearing so much about lately. Love my Prius!!
  14. Capt Ed
    Capt Ed Junior Member
    My 2010 Prius is only one month old, and we are plagued with this same problem. Some of you are laughing, but when you consider these particles are in the air that you breath while driving ....... it's not so funny. This is not common dust, it is something else. I hope someone finds the answer.
    Ed
  15. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Aluminum oxide won't "come off" the evaporator core. Unless something is rubbing it off. It's usually black anyway, though it's true, pure AlO is white. As the new loaner (2010) was also giving you the same dust, I suspect it's in the environment, or perhaps in the shop of the dealership (some kind of cleaning material).
    Try leaving a dark plastic outside to see if any accumulated on it. That would indicate it's in the air.
  16. LeadingEdgeBoomer
    289
    29
    New Mexico
    Did you lend your car to Charlie Sheen?
  17. richard schumacher
    7,664
    1,042
    United States
    Are there any oddball circumstances? Mice nesting in the car, you live downwind from a cement factory...? Otherwise, dust appearing after a couple of days is a fact of life. It's in your old car also, it's just more obvious on the dark plastic Prius dash. Run the cabin fan a lot, vacuum or change the cabin air filter as needed, and use a Swiffer duster every time you notice the dust.
  18. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    Do you or neighbours use wood burners, I live out in countryside and everyone uses them and most cars with dark inside panels suffer this problem from the fine ash.
  19. bisco
    50,814
    could it be the cauliflower or potato part of the veggie interior?:rolleyes:
  20. Capt Ed
    .... none of the above! Thanks anyway!
    Ed
