Expensive rock damage...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by JeffA, Apr 27, 2010.
  1. JeffA
    JeffA "The Batmobile"
    23
    Northern California
    I'm just mostly venting some disgust in the quality of roads, and the careless activity of some material handling truck drivers. There has been much construction activity in my area to improve traffic capacity. This construction has recently cost me a windshield on my truck, and now a windshield among other damage to my Prius. The trucks that haul the gravel and road base in and out of the sites are not very thorough when inspecting for loose material before entering the highway. This leads to many stones and other items falling loose from those trucks when at higher speeds. Again, I'm venting. I've followed protocol and reported the activity to the contractors, and have yet to see any restitution. That being said, my most recent damage to the Prius was an expensive fix... luckily my insurance company called it act of nature and payed for it, only setting me back my deductible. It would seem that I not only took a rock to the windshield, but one though my A/C condenser. The windshield was immediately noticed, however it was during a cold spell and the A/C went undetected until the weather warmed up about two weeks later. All said and done, the windshield (the most expensive I've seen) cost a whopping $630, plus silicone molding $30, plus install $104! The A/C condenser, oil, freon, and labor rounded out the balance of my repair for a total expense of $2300. Seems a pretty steep expense at 10% of the total vehicle cost!
    Needless to say I am looking for accessory grills to fill the areas on the front of the car as I'm sure our local roads will not improve any time soon. Maybe some aluminum mesh like those import tuner cars use? Any ideas where I might find something to inhibit small items from penetrating the front grill areas?
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    I can sympathize as I've had the same thing happen to me, but on my former car. Smack - a rock up from the tire of a truck took out my windshield. Luckily, my insurance covered it as I have something called "glass coverage". Too bad the OBD (on board diagnostics) system did throw out a warning on the dash of "Low refrigerant" so you'd have know something else was wrong. My old SLS had codes and messages like that displayed on the dash. I guess Toyota took the cheap way out. Had you gotten a warning message or code, you could have included that in the insurance claim.
  3. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I'm not trying to say it was your fault or anything. I work in construction and just wanted to add my thoughts.
    1. The groves in the big trucks tires will pick up rocks from the road the fling them backwards( this is the reason alot of times they are not at fault). Also I have seen a large baseball size stone get stuck between the two tires on the back of the truck. If you see this stop cause if you are to close when the truck picks up speed it can kill you.
    2 If loose gravel or stones are falling out of the bed of the trucks or off the frame, or on other parts that may have picked up on a job site, they tend to fall off the truck then bounce a few times. Leaving a 4+ second following distace will prevent any major damage.
    3. Just don't stay behind them, or if you can stay back untill you can pass.
    4. If you do see a truck and stuff is falling out of it, call the company the the truck belongs to. Call the contractor that is running the job, tell them your going to call the local news about how there truck drivers are careless and not cleaning off their trucks before leaving the jobsite, I'd bet they will be out there with little brooms shortly after. Call the local road and highway division and tell them about it.
    Most companies tell there drivers to always clean off any lose dirt/rocks/ashpault before returning the road.
  4. fuzzy1
    10,332
    Or, depending on your state, skip the local news and call the State Patrol. Here, that stuff falling off is an unsecured load, a ticketable offense. And since some high profile fatalities and a very serious maiming, it is now a potential criminal offense.
  5. adamace1
    1,403
    193
    Charlotte, NC
    Right. I would think most states are the same.
    If people start calling i would think things will improve. I never have drove a truck, but if i did i would do the best job i could to prevent damage to others.
  6. socratesthecabdriver
    283
    31
    greece
    wow i thougt things are bad in greece! we got similar problems on the greek throughways with opend top trucks that carry peble and queri stones that are used for mixing cement! we have no comercial roadways 2 weeks ago had to change lanes radicaly to avoid stone flying out the back of one! the passsenger needles to say wet her self but i saved my car! i was thinking i wish i was back in the states where thing like that dont hapen!:frusty::doh::drama::tape::ballchain::tea:
  7. New_Yorker
    New_Yorker New Member
    517
    69
    Headlight shields and paint protection film are a wise investment. Not allowing yourself to follow a gravel truck or a concrete mobile style cement mixer always makes sense. If you live where they salt and sand roads, stay home when they have the road sanders out, or just stay away from them.
  8. JeffA
    23
    Northern California
    Thanks for the comments. I must say though that this is not my first prom. I was not following a truck when this happened... I've learned that lesson long ago in my 30 years of driving. This was normal vehicle traffic on roads that were failed to be kept clean after construction traffic. The truck traffic is supposed to enter the highway after passing over a large stone based section, put in place to shake debris from the truck and trailer. I have personally witnessed the drivers turning onto the highway before the "shake bed" in order to pick up more speed. So when they do pick up speed and meet the highway, they tend to dump said debris right at the point of the road were they jump on. Then normal vehicle traffic passes over this debris and picks it up in tires and the rest is history. I was lucky that my insurance decided to pay for both the windshield and the a/c condenser. I was more mad at the cost of the dealer labor than the event that caused it, but it was all a compound injury that caught me at the wrong time. Now that this is all said and done, the construction is starting to come to an end. The trucks are gone, the new road is paved, only some striping and lane transitions to be done. I've managed to steer clear of ALL vehicles in my latest travels through this section. This was but only one isolated incident, the highways all over California are in dire condition, all relative to the state of the state in general. Hopefully the budget comes back and CAL-TRANS gets off their butts and does wht they are meant to do. I don't knock the work they do, only the work they are unable to perform due to budget cutbacks. I look forward to the days where you can travel at 70 mph and be secure in knowing you will not fall into a pothole the size of a volkswagen!
  9. Superdrol
    Superdrol Member
    399
    32
    I was driving on the highway yesterday and a semitruck's tire burst throwing all that garbage behind it, fortunately I was in the lane adjacent to it, but it was flinging debris all over the place.
  10. Carnutt
    Carnutt Member
    232
    23
    SW USA
    2018 Prius
    I too sympathize. On the way to trading in my old car, a rock damaged the windshield requiring me to replace it. The windshields on my cars are full of dozens of nicks, not to mention the cars themselves. It amazes me how far back behind a truck I actually am when a rock or stone smashes into me like a bullet. In fact, I've been as much as 300 feet or more behind the offending vehicle :eek:.
    Thus far, I have no solutions(s) :(.
