Extreem changes
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Fred V, Aug 14, 2005.
  1. Fred V
    Fred V New Member
    Schenectady
    I am now putting an '02 prius FWD system into my existing '96V GE RWD EV (it is in a '67 Jamaican body) and need info on making the prius system plug in. I am also rebuilding an '03 prius that has an easy hit in the nose. I am not interested in any warrantee violations since I have no warrantees---so anything goes;-) Since I now have 2 battery packs and the Jamaican will not be done till next summer--- has anyone ever hooked 2 bats in parallel?
  2. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
    Yes I think this has been done, but I do not know all the details. Keep in mind that the battery pack includes several voltage, current, and temperature sensors. Form all this information the battery ECM decides what charge and discharge rates it can use, and how fast to run the battery ventilation fan. I suppose that a second battery in parallel would cause some changes, but the ECM might have trouble making sense of them.
    I really admire the idea of the hybrid drivetrain transplant, and hope you can take photos and write descriptions of the project.
  3. Fred V
    Fred V New Member
    Schenectady
    Thanks for the info. I have not gotten the '03 yet so really cannot see how the batt is set up works yet. The car is being shipped in from Min next week. I will post some pics of the Jamaican for you---but since I have already removed the body and cut the front half of the frame off---it ain't that much to look at;-)LOL I do have all the '02 prius parts (including the fire wall) that I am putting in it but they are all over the place---I will have to post more then one pic if you want to see the WHOLE mess;-) Ya really want to see such a mess---it could make you sick
  4. T_S_Kimball
    T_S_Kimball Ambassador from Uru
    42
    Hoboken, NJ
    I would not mind seeing such photos Fred.
    As an owner of both Prii in the past two years, I'm most curious about mods and the inner workings of such a cool vehicle.
    Even if it is in pieces. ;)
    --TSK
  5. Fred V
    Fred V New Member
    Schenectady
    OK lets see if I can do this---This is what is left of the RWD 96V GE drive system from what was a '32 Alfa Remeo EV I had and will become the rear weels of the Hybrid / EV I am building. The pic is too big will have to reduce them and try again latter---sorry, I am not to good with this pc stuff;-(
  6. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I don't see why you can't hook three in line.. just guessing.. my knowledge is primitive to toyota's, but I have built a hydroelectric system that has been in operation almost 20 years now....
    The system reading current, voltage, and temp should not be adversly affected by having a bigger bank. I don't know if the system would have any problems at all.. or maybe it will merely see everything the same? The reality of it would be that it would just take longer to charge up the whole bank and longer to discharge it?
    I would try to get ahold of a toyota engineer if possible, but and easier route may be to talk to the guy who has already altered it successfully?
    http://cbsnews.cbs.com/stories/2005/08/16/...ain781291.shtml
    He may not want you to steal his thunder...... a toyota guy may be more honest?
    My hydro systems were not near as complex as toyotas computers, but I could use 4 golf cart batteries, or I finally went to 6000 lbs of lead calcium telephone batteries and I didn't have to change anything else.
    The voltage would still be the same... current wouldn't change because thats based on the cars demands... the only real difference I see is the time factor.... it will take different time lines to fully charge verses fully discharge with a bigger battery bank.
    I would love to see someone try it... sounds like you could just be the guy?
    Not very many have the means "and" the knowhow "and" the money to try it?
  7. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Currently, the battery SOC is determined by the voltage at each module. The battery ECU in the battery cage takes these readings and from them determines battery SOC and condition.
    Adding a pack in parallel at the ends could accomplish one's goal, but may not be perfect, since only the original pack's condition would be monitored and known.
    Also the current flowing into and out of the battery is also monitored. I'd say it would be best to attach the additional packs as close to the original battery pack as possible, with the current monitor outside the connection, so the current monitor reads current flow into and out of all packs.
    The connection wiring should be adequate for the voltage and current involved.
  8. windstrings
    6,280
    378
    Central Texas
    What are your opinions on mixing the battery types?... if you can get a gelcell set as close as you can to 201 volts?.... 17 X 12v = 204 volts... that may do it?
    I wonder what the resting voltage is of the original battery pack?
    If the added batteries were consistently higher... they would want to dump energy into the lower voltage bank, thereby overworking themselves...
    thats why its bad to mix new and old batteries.. the old bring the new ones down to their level.. .but in this case its a bit differerent... we are really dealing with voltages.
    If the added bank was a bit higher in voltage.. they may wear out prematurely?
  9. Fred V
    Fred V New Member
    Schenectady
  10. Fred V
    Fred V New Member
    Schenectady
    I got the '03 almost 5 weeks ago and brought it to get the rails pulled. After 4 weeks of getting jerked around they finally admitted they were afraid to get electrocuted so I took it to another shop. It is supposed to be done this week. As for the other hybrid with the kit car I have not even had a chance to do anything further on it with all the running around getting parts and info from toyota before anyone would tuch the damn thing;-)LOL Well I should get the '03 back soon and will have a few days work putting the fenders and crap on in and then pain the thing---THEN I will be able to get back on the hybrid kit car and will keep you posted with pics as It goes along. Thanks for the info on the Batt's---I am not sure if I want to play with the '03 and end up no toys until the kit car is done---no guts no glory;-) I KNOW I will put the two Batt's in the kit car when it is done. Well, if all the bull crap is over I can finally get moving on this thing.
