First start-up on a cold(ish) morning...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by theothergoose, Oct 28, 2007.
  1. theothergoose
    theothergoose New Member
    27
    Okay - I've done a search on this question, but I'm still not sure...
    Yesterday morning after the first cold night out (maybe 40 degrees or so), the ICE sounded awful upon startup. Sounded like a bucket of bolts for the first few seconds... not what I was used to. The engine, of course, settled down after a while and was its normal smooth self for the rest of the drive. My search turned up a mention of "retarded timing and a stoichiometric mixture" in cold-weather startup situations. Is this the cause of my bucket-of-bolts-type clattering?
    Thanks for any insights on this one...
  2. bwilson4web
    15,932
    <div class='quotetop'>QUOTE(TheOtherGoose @ Oct 28 2007, 09:20 AM) [snapback]531545[/snapback]</div>
    Do you have an engine block heater installed and in use? This summer I found that using the engine block heater results in a 'knock' for the first 1-2 seconds when the ICE actually starts burning fuel. The initial 'spin up' doesn't have this knock. But so far, I've not been able to isolate the source.
    How long ago was your last engine oil change and what did you use?
    Thanks,
  3. theothergoose
    27
    Thanks for the reply.
    Nope - no engine heater of any kind. The oil was changed by the dealer about 750 miles ago. I can only guess at the oil type used, but my dealer has always provided quality service; I doubt the oil is causing a problem.
    The engine rattled to such a degree that I was somewhat concerned at the time. I've been around cars for some time, but this is my first hybrid. I understand that the Prius ICE is an Atkinson-cycle engine, and I wonder if this may be a factor with the cold-start rattle. In short, I'm trying to get a better understanding of what's going on under the hood so that such odd noises can be accepted as normal operation.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Mine has never made such a noise, even at -40 parked outside at my hobby farm. Get it checked
  5. richard schumacher
    7,664
    1,042
    United States
    Start by checking the oil level.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Are you sure the sound you were hearing wasn't the coolant pump for the 'thermos'? It can sound pretty loud/noisy as it's pumping when it's cold.
    Also, you may have some rough shut-offs of the ICE, particularly the first one of the morning...there can be a little 'dieseling', but it should be brief and not continue with normal operation.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The engine on the Prius does sound a little like a diesel. The Atkinson cycle makes it clatter a bit more than normal, and the engine soundproofing is lighter than on many cars. That's probably what you are hearing, but if you have any doubt, have someone with Prius experience listen to it.
    Tom
  8. drifty1955
    drifty1955 New Member
    100
    <div class='quotetop'>QUOTE(TheOtherGoose @ Oct 28 2007, 02:35 PM) [snapback]531623[/snapback]</div>
    Oh lordy put some decent oil in that high tech car of yours. If your dealer is like mine they will put the sh*ttiest oil in it they can. Not to break your chops but if your quoting "Atkinson-Cycle" and then guessing what kind of oil is in your car your making so little sense you makin' my head hurt. Run..don't walk and put some Mobil 1 10-30 in your car and then buy a EBH from PriusChat.com.Thank you. That is all.
  9. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    <div class='quotetop'>QUOTE(TheOtherGoose @ Oct 28 2007, 11:35 AM) [snapback]531623[/snapback]</div>
    What octane fuel are you using? Also, try another station. You might have contaminated gas, it sounds like a knock to me. (pinging)
  10. theothergoose
    27
    Checked the oil - the level is spot-on.
    I've been using 87 octane. I'll try a different source. At this stage, I'll keep and eye (or an ear) on this situation to see if it happens again. Thanks for all the suggestions! :)
  11. GaS
    GaS Junior Member
    24
    Muncy, PA
    My Prius hasn't done it yet, but my 05 Corolla S two or so times in teh winter had a noisy start. As has my wifes 98 Stratus. Just once in a while, things sound much more noisy than normal. Always scares the crap out of me, probably happened less than ten times over the past ten years, but I consider the rare noisy startup normal.
    Oh, always used M1 oil, usually use PureOne or Wix Gold filters.
    There is something called an anti drain back valve in oil filters that helps keep oil in channels ready to lube stuff as soon as the engine starts turning over (rather than having to be pumped back up from the pan). I suspect that our oil filters are using this method, and once every blue moon the valve doesn't seat entirely and the engine clanks until oil smothers everything again. Just a uneducated guess.
  12. enviroprius
    enviroprius Junior Member
    91
    Sonoma, CA
    This just happened to me today. Had not started it in 3 days, but it was 73 degrees outside and it was shuddering and knocking so bad, I turned it off. Just had an oil change 250 miles ago. 90K on the car. This has never happened before. Thoughts?
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Did you move the car in the driveway (i.e. very short engine-on time), then let it sit overnight, and then experience the shaking the next time you started the car? If so then this is consistent with what many others have reported.
    Rough engine start | PriusChat
  14. Patrick Wong
    18,200
    6,490
    Check the engine oil level on the dipstick.
  15. enviroprius
    91
    Sonoma, CA
    Yes. That's exactly what happened. It was moved from across the street. Thank you.
  16. 2009Prius
    2,705
    511
    63
    OK that's probably the same phenomenon reported by many in this thread
    and there is nothing we can do about it.
    But just in case it is still a good practice to check the oil level as Patrick suggested.
  17. wjtracy
    wjtracy Senior Member
    11,358
    3,606
    Northern VA (NoVA)
    ...this is where the retrofit EV button would be nice to allow moving vehicle without ICE
  18. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Absolutely true. This where I often use my EV button.
    Interesting thread 2009. Apparently it's something that can happen to various modern cars when the engine is cold started and run for only a very short time. My brother once did this in his 2006 Mitsubishi colt. He moved it just a few meters to get his other car out, and then went to start it a few days later and it coughed and spluttered and wouldn't even start! After several attempts he called a mechanic for roadside assistance. After giving the mechanic the back story he then started it immediately just by cranking with full accelerator pedal (which of course is something you'd never normally do in a modern fuel injected car). Apparently he said it's fairly common problem and is similar to "flooding" in an old carburetor engine.
    Personally on the Prius I make a habit of allowing the ICE to complete it's warm up cycle and cut out before shutting off in the case where I accidentally let the engine start when just moving the car a few meters (I say *accidentally* because it's only if I forget to use the EV button). I've never really thought too hard about why I do this, but I guess it's a good way of avoiding this problem.
    Agreed +1. With any engine problem happening soon after an oil change it is worth doing this. Actually let me rephrase that: Problem or no problem, always check the oil level *yourself* after anyone changes your oil.
