Fluids for 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sprius*, Nov 10, 2009.
  1. sprius*
    sprius* Junior Member
    New Jersey
    Where can you get all the fluids you would need for the 2010 Prius (engine/power control unit; steering; brake; transmission; oil)? And is the same coolant fluid used for the engine cooolant and the power control unit?
    Thanks.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    At your local Toyota Dealer, parts department.
    p.s. bring lots of money.
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Is there a reason you're wanting these??? The transmission uses a special Toyota synthetic - and does not need to be replaced (at least not in the first 100K miles). I found this today when I took the Lexus GX in for a transmission service. Not sure about the Prius - the Lexus doesn't even have a tranny dipstick. To change the oil you have to go under the car, and after draining/service *pump* - yes *pump* oil into the side of the transmission. To add to the exacting science - according to the docs, you pump fluid in until it overflows from the side plug...
    It seems everything has a very very long life......
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    The owners manual says everything about oil and fluid.
    Please refer to page 560 to 564 of the specifications section.
    Ken@Japan
  5. jonehill
    jonehill New Member
    usa
  6. sprius*
    New Jersey
    Just in case I ever needed to top off any fluid; I want the right stuff. Thanks.
