FM Radio Settings Reset
Discussion in 'Gen 3 Prius Audio and Electronics' started by Mide, Apr 26, 2014.
  1. Mide
    Mide Junior Member
    I usually listen to 1 MP3 CD loaded with songs, played on random. On occasion I will jump through the stations to see what's playing there as well. Around 4-6 times already I will be listening to a CD song and then the audio will cut out and the system tells me it can't read the disc or that I need to eject the CD. After I eject it and re-insert it, the memory on all of the FM stations will be reset.
    I'm out of warranty and have learned to live with it but was just wondering if this has happened to anyone else.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    Check your 12V battery. The FM station resets are indicative of a low 12V.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Or a loose connection on the back of the head unit......or a loose or intermittent fuse.
  4. Mide
    Mide Junior Member
    Will go and check the battery, thanks.
  5. bigrin
    bigrin Junior Member
    59
    Ann Arbor, Michigan
    2014 Prius v wagon
    Usually the battery.
  6. Mide
    Mide Junior Member
    Battery is at 12.55v which is still fine, so not that.
  7. jdcollins5
    5,131
    1,342
    Wilmington, NC
    How did you check the battery? Did you check it with a load?
    If so, then it may be a loose 12V connection to the audio unit.
