Fog Light Installation Help
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sckling, Dec 19, 2009.
  1. sckling
    sckling New Member
    Los Angeles
    I bought a pair of fog lights from eBay and read the entire fog light installation thread and downloaded the installation instructions from tjp74, Jim, hawkniin77 and all other people (thanks guys!). I still have one thing that I'm not exactly sure how to do. I want to skip the stalk part and just have the fog lights turn on together with the either the low beam or park light. If I want to avoid wiring wires through the firewall, where's the best place to tap the switched power (inside the fuse block I assume)? Another thing is can I just use all the existing wires that come with the kit without any modification (any safety concerns)? Will I get warning lights if any of these fog lights burnt out? Thanks for the help!
      File size:
      72.8 KB
      832
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The way I see it, you are not going to be able to avoid running the wires through the firewall. As noted in the doc, you will see where you can do that. Two wires were needed, a power in wire (tapped from the fuse box under the hood and out power from the relay to the lamp harness).
    As also noted in the doc, the relay can be stuffed under the upper left hand of the dash where there is a brown wire leading into a ECU. This wire is hot when the parking / headlights are turned on.
    I used the entire harness that came with the light kit. The only tap I had to do was into that brown wire mentioned above.
    No warning for burned out lights.
  3. sckling
    sckling New Member
    Los Angeles
    By the upper left hand of the dash, do you mean where the ECU is located? And is it better to place the fuse and relay in the engine compartment (inside the fuse block?) or next to the ECU?
    Thank.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I placed the relay and fuse behind the upper left hand side of the dash next to the ECU that had the brown wire, yes. The two wires I ran through the firewall.
  5. jayvee
    jayvee Member
    341
    89
    WA
    You don't need to go through the firewall.
    You need a 12V relay inside the engine compartment that will switch in the high-current power for the fog lights (which you can tap into at the engine compartment fuse block, using a wire with an in-line fuse). The "control" for this relay (the power going to its coil) will come from tapping into either the low beam or parking light line (12V side, not ground) inside the engine compartment. You don't need any other switch or control. The small amount of current the relay's coil will draw will pose no threat to the existing light wiring. You do need to be careful about the high-current line(s) to the fog lights themselves, though. They should be at least 16 ga each. Some have tapped into the fuse box at an unmarked lug in the fuse box - there are photos in the post - I'm not sure what that lug is for, or how much current it can handle, but I suspect it's probably OK.
    You will get no dash warning if the fogs go out.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thanks for pointing out this alternative jayvee.
    The only downside to this wiring configuration is that you won't be able to turn off the fogs if the parking/headlights are on. For me I like to shut the lights off as I am going up the parking garage so the engine won't have to come on to charge the battery.
  7. sckling
    sckling New Member
    Los Angeles
    Do you know where exactly is the "unmarked lug"? When you said tap into the low beam or park light line, do you mean tap the 12V switched power wire (the red one) directly to the purple wire that attached to the H11 bulb? Many thanks!
  8. mayfair1572
    mayfair1572 New Member
    new jersey
    I have 2010 Prius IV and am interested in installing fog lights as well. Can you tell me precisely which fog lights you purchased and from where so that I'm certain they'll work and of course fit the factory fog lamp covers.
    Thanks.
