Foglight Kit Moisture/Condensation Issues
Discussion in 'Gen 3 Prius Accessories and Modifications' started by rudiger, May 21, 2011.
  1. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Back in July of last year, I installed the OEM foglight kit and replaced the lightbulbs with a pair of yellow Luminics JDM 55w H11 bulbs.
    A few months later when it would rain or snow, condensation began appearing on the inside of the foglight lens on both sides. It would burn off when I left the foglights on for a while, but would reappear shortly thereafter. The driver's side would generally stay clear most of the time but the passenger side would always have moisture on the inside.
    Then, a few months ago, the driver's side bulb seemed to burn out. Today, when I took them apart to reinstall the clear lightbulbs, it turns out that fluid (it actually looked like windshield washer fluid) had gotten inside the connector and shorted it out, actually melting some of the plastic to the contact. It took a while, but I was able to scrape off enough of the plastic from the contact to get it to work with the JDM bulb again.
    I also cleaned off the inside of the lens on the passenger side and put everything back together (including the JDM yellow lightbulbs).
    While I had it apart, I noticed a small, rubber plug on the bottom of the foglight housing. Does anyone know what this is for? I wonder if it should be removed to allow the condensation to evaporate.
    Has anyone had the same or similiar experience and, if so, how did they rectify it?
  2. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Generally you want the light housing completely sealed. No holes in them. Are you sure you had the bulb mounted correctly? Sometimes if they are not seated properly you can get moisture inside or if you installed the bulb during high humidity. If it is completely sealed there is really nowhere for the moisture to go except turning from liquid to vapor back and forth. Try installing your bulbs when it's not humid?
    You can also try removing the whole foglight then inspecting the seam between the lens and housing for gaps or cracks. I would suggest putting a bead of RTV sealant along the seam just as a security measure. There could be a small gap that is not visible. The RTV will seal it up for you.
    The small rubber plug on the bottom of the housing is there as a release for air expansion when the air inside the housing heats up. This is to help keep the light from cracking.
  3. rudiger
    696
    45
    Cincinnati, OH
    Those are good suggestions. In fact, I did the RTV thing around the lens. It looks like there's a place where the rubber O-ring did not seal properly between the lens and the housing. Maybe this is where the moisture got in in the first place.
    Or, as suggested, it happened when I changed out the lightbulbs. It should also be noted that the new lightbulbs seem to have a rubber gasket that is more flexible than the one with the original lightbulbs. That could also be a factor so I swapped those.
    If it's the O-ring, once the housing is sealed by the RTV, the issue then becomes that there's existing moisture inside the housing that simply has nowhere to go and alternates between vapor and condensation, depending on whether the light is on or not.
    Thanks for the help.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Had the same thing happen to me but with the headlights. I replaced the parking lights with LEDs and soon afterwards had condensation in the units. It has since cleared up and has not returned.
