Found this on key ring. Any ideas?
Discussion in 'Gen 2 Prius Main Forum' started by JohnRobinson, Apr 20, 2010.
  1. JohnRobinson
    JohnRobinson Junior Member
    99
    29
    Norway
    Hi all
    About to sell the car and found this metal plate with number on. Any ideas what its for? :confused:
  2. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    That's the key code for the metal key which works in the driver's door lock. This key is used to open the car if the car is locked and the 12 volt battery dies with a dead battery, or to lock the car with the car in the Ready mode. With those code numbers a dealer can make a new mechanical key.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    mechanical key?... but they are easy to make.
    from what i remember, that code is used to identify the smart key system. you supposedly need that code in order to make other smart keys as it identifies your cars receiver system.
    i could be wrong... but i heard of people losing that key and things being a pain for programing new fobs.
  4. JohnRobinson
    99
    29
    Norway
    So something to do with the key. Pretty impoartant then. Iæll keep it safe. Thanks for the help.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It's the key code for the mechanical key. Locksmiths can "code cut" mechanical keys from the numbers, which is how you get a new key if you lose your only copy. I have code cut keys using a file and a pair of calipers.
    Tom
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    So ideally one would keep the code plate somewhere safe at home, maybe together with the title of the car.
  7. qbee42
    18,058
    3,076
    Northern Michigan
    Exactly. Some dealerships keep them, since owners usually lose the number plate along with the keys.
    Tom
