Fresh air / recirculated air
Discussion in 'Gen 2 Prius Technical Discussion' started by coltonman, May 23, 2008.
  1. coltonman
    coltonman New Member
    Dania, Florida
    I notice that when the a/c is on, I can push the fresh air/recirculation button on the dash and nothing changes when the setting is for vents only. If the floor vent only option is used, then when I push the fresh air/recirculation button there is a definate change. I took off the glove box to observe this and was right...the outside temp was 90 degrees. Shouldn't the flap be open on recirculation......and closed for outside air? When I put it on floor vents only this works, floor and vents doesn't...is it a relay or what? Can anyone offer light on this before I waste a day at the dealer? A/c works fine.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I'm not sure I fully understand your question. First, when you use the term A/C, are you using it in the standard U.S. way meaning mechanical cooling, or in Toyota's way which means heating and cooling? Second, there is no fresh air/recirculation button on the dash. Do you mean the one on the MFD, the one on the steering wheel, or both?
    Tom
  3. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I think you interpretation of door position is backward.
    The air door behind the glove box should be "closed" for recirculated air and "open" for fresh/outside air.
    If the door moves upward it "closes" the outside air off, if it moves downward, it "opens" the outside air to the cabin.
    The position of this door, during automatic operation, depends on many factor including temp differential, moisture level, and inside temp setting.
    Anything you see as "unusual" may be associated with automatic operation perameters and your interpretation of door position. Take it out of automatic and operate everything manually, and see that it all functions fine.
    Then go back to automatic, and set it to 77 deg. (in the summer) and forget about it.
    I think your interpretation of door position backward
  4. coltonman
    Dania, Florida
    It seems to be working fine now....must have been hot day (92). I tried it this morning (78) and it looks ok. THANKS!
  5. donalmilligan089
    239
    22
    virginia usa
    How do you operate fresh air manually wiyh out ac coming on
  6. donalmilligan089
    239
    22
    virginia usa
    does the ac light on dash always come on whether heating or cooling?
  7. johnjamis
    johnjamis Junior Member
    79
    KY
    If you select the dash outlets only, you can not get ventilation without ac. Select dash/foot and ventilation will then work with fan speed controlling flow rate.
  8. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Turn the ac button off, turn on the fan, and set the temperature to 'max cold'.
  9. Evilshin
    Evilshin Member
    119
    The issue, is that the Prius has an Auto A/C button on the steering wheel. It's quickly turns on the A/C for you, but auto A/C also controls things like how much the fan is on and where the air is coming from.
    If you want to manually over ride this don't use the auto a/c button, use the MFD climate screen. Now there is one annoying issue with this, the prius tries to learn what you want and often assumes that by pushing one thing, you mean you want the usual... So if you are doing things that don't match your habits, it might try to "assist" you inappropriately.
    Auto A/C can be turned off by manually selecting the fan speed. Then you can turn on or off the A/C... but if you've used the auto a/c a lot, turning on the A/C on the MFD may turn on the auto a/c, if so, just select a fan speed. Then you should be able to select your desired air path.
