Front Brakes or Wheel bearings...??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wb9tyj, Jun 14, 2009.
  1. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    04 Prius...with 114,000 miles...now we have a new noise up front...
    if any of you know what an A-10 Wart Hog sounds like starting up the turbines...this is similar...start driving down the road, whoosh- whoosh whoosh faster and faster and higher the pitch gets as speed increases...a left or right turn turns it into a metal on metal squeal...as the whoosh continues through the turn...i know the brake pads have got to be getting close to replacement, and i know what a rotor squeal sounds like...but when you turn i know the weight and force distribution changes, to change the sound....but this is weird...maybe we are dealing with both brake replacement and bearings too...??? doesnt make any difference whether the brake pedal is pushed or you are going down the road at 50mph...still have good brakes with no squeal when pushing them on...the the noise continues...with or without brake pressure...any suggestions...thanks...
  2. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi 'tyj,
    The metal-on-metal sound during a turn is usually wheel bearings. But, when they have it all apart, might as well have them do brakes too. Or at least deglaze the rotors.
    Try the down hill neutral braking to try to clean up any rust on the rotors. That might be the whoosh-whoosh sound. Make it a small hill, just in case the metal on metal is pad backing plate on rotor.
  3. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    that's a bearing alright.
  4. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    could also be cv joints
  5. richard schumacher
    7,664
    1,042
    United States
    Get it to a dealer before a wheel falls off. No joke.
  6. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    My SWAG is bearings. Shouldn't be a huge job to replace them. While you're in there, go ahead and throw on some new brake pads. Maybe even flush the brake system and put in some new stop-juice.
    If it's the CV joints, they're probably not difficult to replace, but they will probably not be too cheap.
  7. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    Bearings. You have to replace the whole Hub assembly. Probably $250+ each side just for parts at Toyota.
  8. wb9tyj
    389
    95
    Indiana and Nevada
    thanks for the input...pads are at 3mm/+or-...was quoted $350/side for wheel bearings...
    at dealer shop...and $200.00 more for complete all the way around brakes...lets see 700 +200 =$900.00...i said baloney...i can get the bearings/housing cheaper from wholesaler and the brakes will last a bit more...dealer says its 3 hrs per side...i said you must be taking a lot of breaks in 3 hrs...i'll look elsewhere...see ya...
  9. brownsnoutuk
    185
    119
    Shepherd, TX
  10. wb9tyj
    389
    95
    Indiana and Nevada
    brownsnoutuk: thanks for the link...will probably get at them this upcoming weekend...i was sort of surprised still having some front pads still left ...but im not complaining...
  11. patsparks
    10,664
    567
    Adelaide South Australia
    Did you actually check the wheel bearings and check for foreign objects between the rotor and backing plate? Did you make sure you don't have a stick stuck in the under tray which is dragging on the ground? Yes I had this happen to me.
    Don't buy hubs and bearings until you're sure they are faulty. Check the brake wear indicators, little metal springs that touch the rotors before the backing plates of the disc pads do to make lots of noise to alert you to impending brake repairs. Jack up the front wheels and see if the noise is evident when you hand spin the wheels in neutral and check for play in the bearing by grasping the wheel top and bottom and attempt to rock it sideways. If no movement I doubt the bearings have failed.
    If you have a failed bearing only change the side that has failed. Wheel bearing failure is rare these days on FWD cars due to excellent sealing and fine tolerances.
  12. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    My first guess was brake pads but CV joints and bearings could be it too. Keep us posted on what it really is and we need pictures man.:rockon:
    Is it coming from both sides? If so man Prius should balanced those parts to wear out at the same time.
  13. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    02 gen 1 (for another week at least)
    i foolishly clipped a curb turning a corner (it was a new curb that had been pushed out three feet). I cought it with my right rear tire. This was 3-4 months ago.
    it now makes a noise as the rear wheel spins, and it is noticable in stealth mode.
    When i had the 140K service, they said i should replace the bearings and the wheel, at about $1200 total, which struck me as way too high.
    Is this a safety issue? The car runs fine and is getting its best mileage ever (55 on the last few tanks). It seems like a mild bearing issue, like one got out of round. Can this stay this way untreated and is it safe?
    If i have to take the plunge, assuming the wheel is no good, how much should I pay to replace both the wheel and the bearings?
    thanks
  14. ETP
    2,802
    1,170
    Auburdale FL
    Get a wheel from a junk yard and take it to an independent repair person. $1200 is a little steep man.
  15. galaxee
    9,810
    468
    MD
    anything involving brake fluid in a prius should never, ever, EVER be done by a shadetree mechanic, or by anyone who does not have the proper dealership equipment. it cannot be done the typical diy way and will just lead to the car going to the dealership on a towtruck.
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
  17. fred garvin
    376
    56
    northern virginia
    thx - anybody have an answer to the safety question and what a bearing replacement on a rear wheel should cost?
  18. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    Hi Fred, the WB assy retails about $250 and the wheel 1/2 that. Guessing 1 hr labor for WB, surely less than 2 hr. I don't think you need a Toyota shop for this work because the brake system i snot opened - it is just re-hung on the new part
    Wheels should be available through other channels. A WB from a salvage dismantler with some sort of warranty might not be a bad source.
    I don't see a major safety issue here, although you may be loosing tread rubber quickly of the wheel is very bent. When the bearings finish eating themselves the noise is going to get much louder but I do not believe a rear wheel will fall off.
  19. fred garvin
    376
    56
    northern virginia
    thanks a lot
    the noise is not super loud and doesn't seem to be getting worse
    i am not even sure the rear wheel itself is "bad"
    so much less than $1200. i could order a wheel and a WB assembly from a salvage yard and pay a regular mechanic to do the install
  20. richard schumacher
    7,664
    1,042
    United States
    Doesn't it make anyone else just a little ill to read of someone who doesn't know how to determine whether the bearings or joints are bad, yet they plan to go ahead and do the repair work themselves? (Not you Fred, I mean the OP.)
