Front Drivers Window stopped working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mwhaley99, Jul 3, 2006.
  1. mwhaley99
    mwhaley99 New Member
    63
    I was out in the car earlier and I had the window down.
    Parked the car put the window up and went into the shop.
    Came out 10 mins later and my driver side window will not go down, but I can control all the other windows fine.
    Is it a connection issue ?
    Motor ?
    Or something else ?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Well I think there is only one fuse for all the windows, so if the other three work it wouldn't be the fuse. That leaves the switch, motor, controller, wires, or connectors. If it were me I would just take it in.
    Windstrings just had a problem where none of his would go up or down, I think he said it was a controller module, quite expensive too. Fortunately he was still under warranty, you should be also.
  3. mwhaley99
    63
    Turns out that the right side passenger window is also not working.
    I am going to take into the dealers on Friday and get them to also check the steering recall as well.
  4. Jack Straw
    Jack Straw New Member
    137
  5. jrct9454
    jrct9454 Junior Member
    73
    Vancouver, WA
    The window lock doesn't affect the driver's window, when the driver's switch is used, which I'm assuming from the original post was the case.
    Could be any of a half-dozen suspects, as noted in the second post.
  6. mwhaley99
    63
    Well things are getting worse, well at least a little.
    This morning when I got into the car I now find that the Passenger front window will also not operate anymore.
    So I only have the right/rear passenger window working at the moment, but the way things are going I expect that to fail today or tomorrow.
  7. mwhaley99
    63
    So as I suspected, I came to leave work today and indeed the last remaining window is now not functioning.
    Oh well, lets see what they find on Friday when the car goes in to the dealers.
  8. jrct9454
    73
    Vancouver, WA
    I suspect a computer / controller problem, not a window switch or regulator. Why stuff like this has to be tied into one of the central CPUs is beyond me, but this seems to be the case. Let us know what they tell you.
  9. mwhaley99
    63
    CPU, sounds like a lot of work to me ;)
    Hate to be without my car for more than 1 day :(
  10. mwhaley99
    63
    Well it turned out to be as simple as the Master Switch being unplugged.
    They are all working again :)
