Fuel cover stuck or latch not working? Help
Discussion in 'Gen 2 Prius Main Forum' started by jlr1218, Aug 17, 2006.
  1. jlr1218
    jlr1218 New Member
    How do I pop the cover so I can fill the gas tank? It's stuck. Or the latch won't open it? Only one bar left on the gas gauge. Brand new car - less than 1000 miles - only filled the tank once thus far.
  2. marjam
    marjam Member
    220
    Silver Spring, MD
    The filler door opener is on the floor between the driver's door and seat. Sometimes you have to pull hard on the latch. If the door does not pop open very far try to grab it gently or it will just close and lock again! That has happened to me. If this still won't open it, get thee to the dealer right away! ;)
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    If it's really getting stuck on something, a short term solution would be to have someone pull the lever while you're standing there to try to pull it out... it may be that it's unlocking just fine, but not popping out. If you can open it this way and see any visible debris that was interfeering, then you'll be able to clean it out yourself without a trip to the dealer... if you can't tell wahts wrong and it's still locking up, a dealer trip may be needed.
  4. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    This happened on the Prius I test drove. The leaf-spring in the filler door was bent so it didn't pop the door open. I had to get someone to pull the door open as I pulled the release catch. Then I bent the spring open to fix it.
  5. jlr1218
    jlr1218 New Member
    <div class='quotetop'>QUOTE(KMO @ Aug 17 2006, 08:46 AM) [snapback]304614[/snapback]</div>
    Thanks for all the responses. I fixed it myself. I used a small door stopper to hold the latch in the "up/open" position and then used a plastic library card (slightly thinner than a credit card) to pop the door open. Turns out the latch is working. If I have trouble again 450 miles from now, I'll take it to the dealer and have the door inself adjusted.
