Fuel Guage Stuck
Discussion in 'Gen 2 Prius Technical Discussion' started by paprius4030, Feb 4, 2009.
  1. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    This morning I filled up my Prius only because I came upon a station that was cheap and since I am going on a trip to NYC tommorrow I decieded to fill up even though the gas guage was one pip above half. It was cold 19F and only took 3.8 gals. So now after several resarts on my way back home the gas guage hasn't moved off the one pip above half. After reading several previous posts about the gas guage and the TSB, I think it's because the ECU doesn't recongize that I filled the car since it was such a small amount above 3 gals. My question is will the gas guage come down one the fuel level goes below what it was when I fill up thereby accuaetly reading when it gets close to empty or will it stay where it is until my next fill up? Thanks for your imput!
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It will come down. You are correct that the added fuel did not register due to the small quantity.
    Tom
  3. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    It should reset to read full after being parked overnight. At least mine did.
  4. paprius4030
    2,077
    296
    York,Pa.
    Thanks guys, mine just reset to full this afternoon. It warmed up to 27 so maybe that was just enough to make the gas expand just enough????
  5. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    Mine is a 2007 and it resets after 2 or 3 starts or if it sets for about a half an hour if I fill it from above a half tank. Doesn;t do it all the time though, sometimes it works OK.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    A similar thing happened to my '04 around three years ago. However, in that case they had to replace the gauge cluster and filler pipe as part of a TSB
  7. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    That's nuts. The vehicle doesn't consider 1/3 of the total tank capacity, 1/2 the effective capacity sufficient to register?
