Fuses in the panel under the dash.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chasabel, May 6, 2005.
  1. chasabel
    chasabel Junior Member
    39
    Shady Grove, PA
    Has anyone had to replace a fuse in the panel under the dash?
    I blew the brake light fuse in the process of installing a
    pulser for the third brake light.
    I figured I would try Walmart or some other local auto parts
    first. No luck, so I went to the dealer where I purchased
    the car. The counter person brought out a mini fuse
    like Walmart had. He looked at the fuse from the Prius and
    had never seen one like it. He didn't have any in stock.
    I had him call another dealer nearby (22 miles) and they had
    some in stock.
    For what you pay for the car they should give you a few extra
    fuses as spares especially since they are are a newer smaller
    size fuse that other stores don't carry.
    I don't know if this size fuse is new to the 2004, 2005 Prius
    or if they were also in the Classic.
    Charlie
  2. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    There are 1 or 2 spare fuses in the fusebox under the hood...
  3. rick57
    rick57 Member
    572
    Circleville, Ohio
    Hi Charlie. I don't no why your dealer didn't have the proper fuse. Looking in the '01 & '05 Prius Owners manuals, then looking in the Electrical Wiring Manual ( and from memory ), it appears to be a 7.5 amp fuse for the stop light. Also by the manuals it looks like a normal mini fuse. I am unsure what you were trying to get/what you have. The only different fuses I have seen are used in the Celica and look like 2 mini fuses made as one in some of their circuits. :roll:
  4. chasabel
    39
    Shady Grove, PA
    Rick:
    I will try to take a picture of the fuse that I blew
    along side a mini fuse to show you what I am
    talking about.
    It looks like a mini fuse with the prongs cut off
    but the fuse fits in the fuse box deeper than
    the regular mini fuse.
    Charlie
  5. bobc
    bobc New Member
    361
    Durham, NH
    Yes,
    They are variations of the mini fuse. In addition to shorter prongs, parts of the plastic head along the prongs are missing. The latter is crucial as this is what makes the connection in the fuse box.
    I tried all of the major auto parts places and had to order them from Toyota. $1.95 each. They had to special order them....
