fWT on ScanGuageII?
Discussion in 'Gen 2 Prius Technical Discussion' started by jengel, Oct 5, 2009.
  1. jengel
    jengel Junior Member
    MN
    New to the Prius (just bought a 2006 package 4) and have hooked up my scangauge II to the system and made some observations while driving. My understanding of the Prius engine coolant system is that hot coolant is stored in the "thermos" to speed warm up and it is reportedly able to keep coolant hot for days. My experience with my Prius suggests that fWT as reported by the scangauge does not stay very warm. For example, if I drive to work and turn off the car with fWT reported at 170F at ambient of 60F, I can come back in 8 hours and start the car with fWT at 70F and warm up is not significantly speeded by my eye by any injection of hot coolant from the thermos.
    Is this typical? I can see about getting an actual data log rather than "eyeball" data.
    Is there a way to monitor thermos temp with the scangauge? My reading of the various diagrams suggests there is not a temp sender in the thermos.
    My concern is that my thermos is not functional. Is there a way to verify performance of this system beyond touching the thermos to see if it is hot (vacuum failure)?
    Thanks for the great info and expertise present on this forum!
    -Jon
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Congrats on your purchase.
    Your experience is correct as far as you have observed. The Prius is a cool running vehicle and does cool down fairly quickly. The thermos will not keep coolant hot for very long. The purpose of the thermos is to pre-heat the cylinder head for emission purposes.
    What you can do to check the thermos is to make sure your Prius is warmed up before shut-down. After 8 hours, start the car and watch the scangage during the 8 seconds before the engine starts. You should see the temp go up as the thermos injects into the heads. Then when the engine starts, you should see a slight dip before it rises again. This works best when the temp is cooler outside.
    Wayne
    2 people like this.
  3. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    The coolant, even if kept perfectly hot in the thermos, is going to cool down quickly when pumped into an engine at ambient temperature. The engine is far heavier and has a much higher heat capacity than the coolant in the thermos. I don't imagine the thermos is really all that effective in doing anything much except in making potential buyers think it's a neat idea.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    jengel,
    If it hasn't been said already, :welcome: to PRIUSchat.
    There are many systems -- maybe even all of them! -- in the Prius that
    operate diferently than in conventional vehicles. Here is a good place to
    go for the low down on how the various Prius systems operate:
    Autoshop101 - Automotive Technical Articles
    If you go to the section, Hybrid04 Engine, you'll find a discussion of the
    ICE cooling system. I've posted a link to the index page, because I'm
    sure that you'lll find other things to delve into... the fuel and evap
    system is a real doozy! :p
  5. jengel
    MN
    That is a good point. The engine/transaxle assy is a hefty heat sink, along with all the fluids therein. I wonder what the estimated efficiency/pollution gain was by the engineers at Toyota to include such a complicated coolant system. Then what is the real-world impact?
    Anyone running without the thermos out there care to chime in?
    -Jon
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    170F is not enough to store the coolant.
    John's Stuff - Toyota Prius - 2004 Tech Presentation 40
    "Start condition: engine coolant temp. reaches 85C (185F) or more"
    Ken@Japan
