Garage Door Opener
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Roger Meyer, May 13, 2013.
  1. Roger Meyer
    Roger Meyer Junior Member
    I've just purchased a 2013 Prius Plugin Hybrid Advanced. I live in an apartment building where the garage door opener uses a code to match remotes to opener. I've tried the instructions in the manual to no avail. Does anyone know how to program the garage door opener involving a multi digit code?
    Thank You.
    Roger Meyer
    (Otherwise, I love the PiP, so far.
  2. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    If you call the number (should be listed in the manual) for HomeLink, and provide the make and model of your apartment's door operator, they should be able to help you. I've dealt with them on the phone and found them to be very helpful. Good luck.
  3. larryakoch
    larryakoch Junior Member
    82
    Pomona, ca
    Is it possible to purchase that mirror (with remote) as an aftermarket part?
  4. syscon
    syscon Member
    329
    43
    Edm. Alberta
    In my manual on p. 333 (Canadian model) it states:
    It didn't work for me or it was a typo. The HomeLink should be pressed for 5sec.
    Try it!
  5. rogerv
    1,639
    317
    Yes. Search PC for "homelink" and you should find info on the maker of OEM equipment. If you read any car mags, they advertise in them. Probably available on Amazon and auto stereo shops. For lots of $$ the dealer where you got your car. :)
  6. jfschultz
    jfschultz Active Member
    636
    115
    Germantown, TN
    2020 Prius Prime
    I got mine from Amazon.com and had my local dealer install it for about $325 total.
  7. jfschultz
    636
    115
    Germantown, TN
    2020 Prius Prime
    The U.S. manual also indicates looking for a change in the rate the light flashes. Go by this and not counting seconds.
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :eek:I've had several cars with HomeLink. Even when reading the instructions several times, it confusing. Make sure you put you door opener in the "learning mode" (button on the opener). Follow the instructions, and it's always worked for me without outside help.
