Gas tank question
Discussion in 'Gen 2 Prius Main Forum' started by PikRok, Mar 22, 2010.
  1. PikRok
    PikRok New Member
    25
    Pittsburgh
    When my mom bought her 2006 Prius the salesman told her NOT to let the tank get down below 2 bars because the tank might implode. It sounded kind of crazy to me but is there any truth to this?
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Many of us have let our Gen II's go below 2 bars and never had an implosion...
    The Gen II in the US did have a bladder tank and not a regular tank, but still no implosions.
    The Gen III now has a regular tank.
    This thread would best be served in the Gen II forum so it is getting moved there.
  3. Doc Willie
    1,717
    144
    Out there, somewhere
    The tank will not implode. The danger of letting the tank get too low is you will RUN OUT OF GAS. You may be able to limp to a gas station on electricity, but you risk damaging the big battery.
    Maybe you should should let her believe that the gas tank will implode. That way you will make sure you don't run out of gas.
  4. fuzzy1
    10,332
    And note Doc's emphasis. This risk is much greater on Priuses with bladders than people are accustomed to on other cars. The bladder makes refills and the gas gauge very erratic.
  5. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    I regularly run mine until the first bar is blinking. It still has a couple of gallons in it.
  6. dogfriend
    7,512
    1,188
    Carmichael, CA
    Did he also tell her not to let it get wet because she might get electrocuted? :madgrin:
  7. fo0bar
    fo0bar Junior Member
    66
    Reno, NV
    The Gen I/II bladders are predictable, just non-linear. :) I seem to notice a bell curve in the consumption rate as indicated by the fuel gauge. When I fill up, it stays at 10 bars for a very long time. Bars 9 and 8 stay around for awhile too, but then it drops from 7-3 pretty quickly. 3 and 2 stay around for awhile, and then it's 1 for even longer (though not as long as 10).
    I almost always fill up right after the warning starts flashing. It's usually around a 9 gallon fillup, so there's still plenty of emergency gas left when the warning is flashing.
  8. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    The OP has a 2010 so I would disagree about moving the thread here. But whatever.
    No the gas tank won't implode. But if you run out of gas you -can- shorten the life of the traction battery. Once probably won't hurt, but don't make it a habit. If you do run out of gas don't drive it very far in "EV" mode. This is how you can shorten the life of the traction battery.
    From fo0bar:
    "I almost always fill up right after the warning starts flashing. It's usually around a 9 gallon fillup, so there's still plenty of emergency gas left when the warning is flashing."
    Unless the emergency requires more than 1.5 gallons of fuel. I still don't understand why people run the tank so close to empty. Maybe I'm just too "Swiss like" (always ready for anything, never caught short). ;)
    I fill up at 1/2 tank whenever possible.
