I replaced my rear brake drums/pads/parts a couple months ago. Last week I jacked up the car and noticed the rear left wheel was still spinning with the parking brake on. The rear right wheel wasn't budging at all, as it should. I re-adjusted the star wheel and the parking brake was working again, giving more resistance. Today though, I jacked up the car again and rear left wheel is spinning again. The star wheel went back in. It seems that instead of pushing the brakes up against the drum as it should, the wheel is actually retracting in. Any ideas on what I could have installed wrong? I checked it against the diagram on this repair manual, and it seems to match.
That is weird I don't think you can mix them up side to side and then when you lift up or push the parking brake doesn't that lift the adjuster up and then it drops down on the star wheel when you let it up or vice versa so there's something supposed to be resting against that star wheel when the brakes for parking are not applied right so it seems to me that little piece of metal on the adjuster maybe is not seating properly or something I'll have to go look on a car that I have the drums off but the brakes still intact and see but something like that is going on The star shouldn't be able to just move when the parking break is not applied and the car is ready to roll so it seems like something is not assembled correctly take a picture of it
Apparently, the star is turning the wrong way. Either the lever is on the wrong side, the star assembly is flipped180 degrees, or it was manufactured incorrectly. I've never done rear brakes on a Gen 2 yet, but most self adjusters have a L or R marked on them. Something to check.
Thanks everybody for the comments! You were right - with the brake kit came a brass-colored self-adjuster and a silver-colored self-adjuster. Apparently the brass one is supposed to go on the left hand side. I had them mixed up. They didn't have any L/R markings on them, only the lever arm did. After reassembling the brakes (ugh) with the correct parts, the adjuster seems to be functioning properly and isn't loosening freely.
You now understand the "learn as you go" motto: We do it right, because we do it twice! Bet you never make THAT mistake again. Posted via the PriusChat mobile app.
Don't feel bad. I just replaced the rear shoes, hardware, and self-adjusters on my 2004 Prius. The bottom line is that the adjusters I bought from Advance Auto Parts (12562 and 12563) were mis-labeled for right and left. Another reviewer at Advance Auto said the same thing. I researched at Rock Auto and their 6 brands were basically all mis-labeled also. I know that sounds crazy, but I am convinced that my interpretation is correct. The absolute fact is that when I first removed the right rear drum, the self-adjuster was GOLD colored and the star wheel had a REVERSE thread. The left rear drum had a SILVER colored self-adjuster, and the star wheel had a NORMAL thread. The direction of the threads is the critical point, not the color of the part. I use my emergency brake every time I stop, and it was working fine. I have described my findings in more detail in the attached file.
Best thing to do is just clean your adjusters with brake clean lube the threads and put them back on the side you took them off of and if you're getting new ones in your kit leaving the parts off the side you're working on make sure that the two pieces no matter what color they are thread the direction as the parts laying on the ground on the side that you're working on hopefully that's one side at a time until you get good at it.
You can also just reassemble and work the mechanism by hand a few times before putting the drums on, watch that the adjuster lengthens rather than shortening.
