gen 3 solar roof ambiant to inside air cooling any good?
Discussion in 'Gen 3 Prius Technical Discussion' started by Flying White Dutchman, Jul 2, 2009.
  1. Flying White Dutchman
    4,374
    313
    ok
    like topic titel
    what is the use for the solar roof ventilation system ( yes i now about the AC remote stuff .. i am asking for the ventilation )
    is the difference between the hot inside of the car ( because of the windows ) being suckt out the car and replaced by the cooler outside air really that big?
    any numbers on this or members that have a temp reader to test this?
    or is it maybe just a gadget?
  2. AUTiger
    AUTiger New Member
    Temecula, California
    According to weather.com, on a 90 degree day, after 90 minutes, the car can be 138 deg F. They don't detail tinting or interior color, so this is very generic. Keep the car at 90 degrees is probably an improvement.
    I wonder if the solar roof is good enough to keep your dog/kid from getting baked in the hot sun. And NO, I'm not suggesting leaving living creatures in the car.
    David
  3. Flying White Dutchman
    4,374
    313
    if the outside is 90 and the car can be 138 then i guess with the solar roof ventilation its maybe 118 or zo.. at best...
    but i hope to get some more real life data or toyota data on this.
  4. john1701a
    john1701a Prius Guru
    12,793
    5,274
    57
    The few times I've experienced getting into the Prius on a "hot" day with the solar running, the difference was very noticeable. Surfaces still get warm, but the air is comfortable. You aren't stepping into a furnace anymore.
    Of course, there probably is a deminishing return which only those of us in the north would notice. In other words, cooling with temperatures lower than 95. So the benefit decision is quite different for me from those much further south.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've noted temps 5-10ËšF higher inside vs. outside using an IR thermometer pointed at the floor (not in direct sunlight). No tint, but I do use a HeatShield in the windshield. I try to keep my car parked w/ the rear facing west or south for best solar performance.
    Is it "ambient" inside? No. Is it better than without the blower running? Absolutely.
  6. Flying White Dutchman
    4,374
    313
    only 5-10 higher then outside is a good performance.
    ( ok not forget you use a windows shade )
    that makes a big diff.
  7. Spee1113
    Spee1113 Diehard Dolfan
    Coconut Creek, FL
    I think it works great. I think the biggest help is once you get in the car and turn on the AC (or use the remote from outside to turn it on), the car cools much quicker (in a matter of seconds).
    I'm in South Florida and its been in the upper 90s here lately. The ventilation fan definitely helps. It also helps if you have your windows tinted as well. I am very happy with the solar roof.
  8. Jon S
    Jon S Member
    185
    84
    The Aloha State
    one owner has reported that the deflector glass shatters easily... from the photos, the sunroof panels look awfully thin....
  9. Tideland Prius
    16,401
    Shouldn't be any different from the side window thickness.
  10. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    not thin
    the whole thing feels quite substantial
    but if it gets hit by a rock giong 65 it may break
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i think the difference will vary greatly by how sunny and hot it is, but on average, without measuring, 5-15 degree difference is about right. still waaaay better than nothing at all. one thing i will say...leaving the windows cracked does not do as good a job.
    i drive my Zenn to work and the few times i have gone out during a nice sunny day, i immediately notice that is much hotter in there than the 2010. and i always have the windows open a few inches. (the doors are so light, they dont close very easily if the windows are rolled all the way up!!)
  12. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Anything will break glass if hit at moderate speed. The car feels way better with the SR running. Someone else posted that running the fan with one window cracked a bit also helped. I live in SoCal so I have plenty of sun to power it with. The a/c is really improved in the 2010. I do have window tint 20/50 as well. The moon roof blocks heat quite well and I often drive with the sun shining on me but the window closed.
  13. fred garvin
    376
    56
    northern virginia
    i love the sr but i also ordered a front wndow shade, as that is where the sun is when i park outside
  14. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    With my front window shade (Heat Shield sold on PriusChat store) on, and my aftermarket extra tinting on the back and side windows, I notice my SR fan runs only occasionally. Use them all to keep it cool! :cool:
    Lee
  15. fred garvin
    376
    56
    northern virginia
    my priuschat shield is en route. tinting may be in my future also.
  16. grahamy
    grahamy New Member
    73
    Raleigh,nc
  17. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    If you look up that thread they are talking about a similar sunroof on the Scion Tc not the Prius sunroof.
    My wife leaves work at 3:30 PM everyday and parks in full sun.
    She think it makes a large difference and she uses the air conditioning a lot less. The few time I have entered the car when it was in the sun I could notice the difference.
    Plus it looks neat.
  18. Salsawonder
    1,897
    47
    La Mesa California
    We've had a good hot spell here the last few days and between the SR and the remote AC, I am more than happy with my 2010 Prius. There is no longer the "blast furnace" when you open the door. In this heat I actually look to park IN the sun vs limited shade, use the SR and the Remote AC. I think I may need to send after the Prius SunShade as the one I have is pretty crappy. If you live in sunny climates like Ca., AZ, and such then the SR is a great option and will get plenty of use.
  19. hill
    8,560
    On a COOL day, our rooftop PV system will generate over 7Kwh. On a HOT day, it'll only do maybe 6Kwh. Roughly, that's what ... maybe a 15% drop in efficiency? See where I'm going? On a day when it's 90 degrees outside the Gen III PV panels will max at maybe 54 watts because efficiency drops with increased heat ... and if the sun is 30 degrees from being perpendicular you can knock off another 5 watts or so. The 49 watts remaining will still drive the fan to ventilate I suppose, but I wonder if the loss causes the fan to run slower.
