Gen 3 vs Gen 4 tire PSI recommendations; ZVW51L-AHXBBA model??
Discussion in 'Gen 4 Prius Main Forum' started by Dan Y, Jun 17, 2022.
  1. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    This is more of what one might call an academic question: why do Gen. 3 (in this case taking from 2010 manual) vs. Gen 4 (2017 manual here but I know 2022 is same) have different PSI specifications for otherwise very similar tires (slight difference in speed rating), with 35/33 for Gen 3 and 36/35 for Gen 4? Also why the variation in how much discrepancy between back and front, 2 vs 1 PSI? I did notice a difference in wheel size.
    Also what is this "ZVW51L-AHXBBA model" thing? I could not follow the instructions in the 2017/2022 manual for how to figure out one's model and ascertain if your car was this model.
    2010 Manual: 2010 Toyota Prius Manuals & Warranties | Toyota Owners
    2017 Manual: 2017 Toyota Prius Manuals & Warranties | Toyota Owners
    50,812
    psi recommendations are based on vehicle structure and weight. gen 4 is independent rear suspension, first in a prius.
    i thikthe zvw thing refers to the engine, but all prius have the same engine within generations
    Pulse07 and Dan Y like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,588
    near Brisbane, Australia
    Tyre Pressure will also have a bearing on vehicle driving behaviour. To balance oversteer, they might increase REAR pressures.
    Any of us who remember old Rear Engine VWs and Renaults - will well know how the way they drive depends on both the quality and pressures FR/RR of the tyres.
    Gen 4 has a totally different chassis and body - nothing is carried over from Gen 3.
  4. Billy56
    Billy56 Member
    73
    71
    Seattle, WA
    2020 Prius
    L Eco
    Both cars.....just inflate to 50 lbs pressure and call it good. It says 44 lbs max on the tire sidewall....I ALWAYS run 50 lbs.....better fuel economy!
    Geoff Hejde and Dan Y like this.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I always run max on the sidewall of the tire. I am too chicken to go above tire manufacture max pressure. When you drive the tires heat up and the tire pressure increases especially when we have warmer ambient temperatures This is the reason I fill my tires the indicated max pressure on the sidewall of the tire. Most if not all manufactures recommend that you fill the tires when cold. (Before the car has been driven)
    alanclarkeau and Dan Y like this.
  6. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    I figured out the "ZVW51L-AHXBBA model" is on the plate in the door with the VIN on it. Mine in 2022 Prius AWD-e LE is apparently ZVW55L-AHXEBA.
    44psi is the max # on the sidewall of my OEM Bridgestone Ecopia EP422 Plus tires.
    The dealership actually delivered it at that PSI and I didn't notice until after a 1000 mile road trip we took a week after getting it. After having car few weeks checked the tires because was feeling like rough roads really felt very rough and was wondering if that could be why. STreets/raods are in really bad condition in Brooklyn, NY where I live, and I think were much better on road trip I took early on.
    I don't have really high standards for a smooth ride, the main cars I have ever driven a lot were a 2000 Honda Civic, a 1991 Plymouth Colt hatchback, and an old school VW van.
    It seemed like lowering psi a bit closer to door placard recommendations (honestly can't remember what I have had it set at most of the time) helped have less rough ride but I also didn't drive it that much during school year when my teacher wife took it to work. Starting in April though I felt like I noticed the ride seeming rougher again and getting worse over time: I am probably going to get tires balanced and allignment checked and maybe suspension looked at, but first may play with tire pressure.
    As I mentioned in other post we had BOTH a slow flat on front right and a major blow out on back left and had to totally replace back left tire, noticed both within days though not sure how long had slow falt (after replacing tire checked PSIs and noticed slow flat).
    It now just really increasingly seems like feel every bump no matter how small and there's sometimes weird side to side front bounce, all of which I notice much more at lower speeds.
    It's hard to believe increasing psi will help rather than harming but I will try it again. I actually did try few weeks ago and developed problem that dealership diagnosed as loose alloy wheel lock on the back right wheel where dealership had replaced tire. So I guess they didn't tighten that right. But still having issues with rough ride, side-to-side bounce esp. at low speeds on rough surfaces.
    I might ultimately replace tires, do people have recommendations?
  7. PaulDM
    PaulDM Active Member
    616
    318
    UK
    2022 Prius
    Excel
    37 psi front
    35 psi rear
    Dan Y likes this.
  8. bisco
    50,812
    increasing pressure will not help smooth the ride, it will help mpg's marginally.
    lowering pressure smooths the ride, but don't go under the spec. and remember to check them based on ambient temp.
    alanclarkeau, Dan Y and 2010moneypit? like this.
  9. 2010moneypit?
    314
    122
    Beaumont ca
    agree
    Dan Y likes this.
  10. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    This is what you personally do? Why not the 36, 35 recommended in manual and door? Or do you have slightly different model with different recommendations?
  11. PaulDM
    616
    318
    UK
    2022 Prius
    Excel
    1 psi makes no difference other than semantics
    Pulse07, Dan Y and Mendel Leisk like this.
  12. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    ZVW50 = Regular Prius
    ZVW51 = I believe is for the higher trims like the Four or Touring (2016-2018) or Limited (2019+) designating higher weights and options
    ZVW52 = Plug-In/Prime
    ZVW55 = AWD / E-Four
    I always get confused with the ZVW51
    #12 jteran5, Jun 18, 2022
    FuelMiser and Dan Y like this.
  13. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    There are so many threads at PriusChat about tire pressures that I certainly haven't read all of them, but I don't recall seeing anyone pointing out that the higher the pressure, the smaller the area of the tread in contact with the road: only a narrow band in the middle, which I think would be disadvantageous for handling, especially on wet surfaces. Conversely, underinflated tires tend to have two narrow bands of contact, one at each edge, leaving little of the center of the tread in contact with the road surface.
    These pictures are an exaggeration, of course, but you get the idea:
    https://cdn.discounttire.com/sys-master/images/hd9/h56/8812799164446/EDUtire-pressure_over-underinflation.png
  14. alanclarkeau
    7,045
    7,588
    "the higher the pressure, the smaller the area of the tread in contact with the road"
    That was relevant to cross-ply tyres - RADIALs work quite differently.
    BiomedO1 likes this.
  15. fuzzy1
    10,332
    This has been both claimed, and disputed for most modern steel radial tires, in very many threads here. It seems that the number of drivers who get more even tire wear at increased pressure, has exceeded those who experience excessive center wear.
    For old-era bias ply tires, there seems to be no dispute about the connection between overinflation and excess center wear.
    There are at least two separate wet traction issues: wet traction without hydroplaning; and hydroplaning itself.
    All the technical information I've seen on hydroplaning shows that higher tire pressure pushes up the speed at which hydroplaning starts. Between living in an often wet climate zone, and having experienced premature hydroplaning on a couple previous cars when tires were set to the car manufacturer recommendation, I've since been a proponent of at least somewhat boosted tire pressure. It turns out that both my independent mechanics (for different car brands) feel the same.
    As for non-hydroplaning wet traction, that issue seems to be ... disputed and unsettled.
    alanclarkeau likes this.
  16. Doug McC
    Doug McC Senior Member
    1,041
    391
    Midwest
    2022 Prius
    FWIW: 2022 Nightshade, 17” tires the recommended pressure is 33/32.
    Pressure recommendations are based on a lot of things including suspension components, even the wheels (which actually have tire pressure limits too).
  17. NewHybridOwner
    607
    282
    W. Michigan
    I looked at a few different tire manufacturers' and tire stores' Web sites, and they all say the same thing as I wrote originally -- and with similar pictures, and with no suggestion that it is not still a problem with radial-ply tires.
  18. fuzzy1
    10,332
    Recommended tire pressures are a tradeoff between competing goals, and it seems that car makers very heavily weight the ride comfort goal. Empirical evidence from the hypermiling communities suggests that numerous of those door placard labels are biased in the direction of underinflation, at least for tread wear. The number of experimenters getting better treadwear with increased pressure, in the form of reduced edge wear, seemed to greatly exceed those who experienced center wear. This suggests that the breakpoint between 'correct' inflation and 'over' inflation, is higher than most of those drivers use, and well above what most of those car maker put on their recommendation labels.
  19. Mendel Leisk
    40,236
    They roll out of the factory at max sidewall, mainly for shipping concerns, and possible protracted parking. Dealership was supposed to drop the pressures, but basically dropped the ball. Mention to service manager and you might get a free oil change or sim. You pay a pretty penny for PDI, and they rip you off.
  20. fuzzy1
    10,332
    ^ A good many of us received our Gen3s with at or very close to 40 psi in the tires, and not lowered at PDI. Then a good numbers of Gen4 buyers reported getting theirs with about 50 psi.
    I believe some tire models for these cars have sidewall label max ratings of 51 psi, but most are marked for 44 psi.
