Gen II Inverter Questions
Discussion in 'Gen 2 Prius Technical Discussion' started by PEB, May 25, 2010.
  1. PEB
    PEB New Member
    Indiana
    Does anyone know what the peak current rating and over current trip level is for the IGBTs used in the Gen II Prius Inveter's 3-phase bridge on the motor drive side? Also switching frequency used?
    I understand that it drives motor at 500 volts and 50KW. I need to know the peak phase current I can get out of a Gen II Inverter Motor drive without tripping the driver board current limit. I want to use inverter for a DIY EV conversion.
