Gen III Prius fuse type? (12V outlet)
Discussion in 'Gen 3 Prius Technical Discussion' started by Philosophe, Dec 22, 2009.
  1. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    The owner manual is silent about the fuse type used in the Prius (the low amps one, like the one used for the 12V outlets).
    I bought standard ATC 15A fuses and, as I needed to replace one (120V inverter plugged in 12V outlet that tend to blow fuses easily...), found out that the Prius fuses have shorter "legs" than the ones I bought. I can use regular ATC fuses, but they protrude and prevent the fuse box cap to be put back in place.
    What is the exact type of the fuses? I haven't been able to find where to buy some.
  2. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Some call them "micro" ATM fuses - they are not available at most spots...
  3. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    I googled ...
    try tessco.com for mini fuses.
    edit: right, probably should be low profile mini fuse, and
    amazon has several assortments.
    Also, I will need to pull some and look more carefully ...
    and make a list of all the fuse ratings used.
  4. Philosophe
    437
    72
    From their website, if this is mini-ATC, which is not the correct format. The metal pins should barely exceed the plastic part.
    They seem to be micro-ATC fuses. Having the correct name (thanks rrolff), I found them on eBay. This new format is certainly not common yet, as a search gives only 1 provider, specifying they are for Toyota vehicles.
    So, the correct type is micro-ATC.
  5. RodJo
    RodJo Member
    423
    56
    Boston
    They are called "low-profile mini" fuses. You can get them from Littelfuse. I got a variety pack from Amazon:
    http://www.amazon.com/gp/product/B001FXN6JS/ref=oss_T15_product
    (Read the comments because the image/description is not correct. You get 55 low-profile mini fuses for $14.)
    I've also seen them at AutoZone.
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Very hard to find. I found them today at Advance AutoParts
