generator pwn line connection malfuncion
Discussion in 'Gen 2 Prius Technical Discussion' started by prius1234, Mar 18, 2008.
  1. prius1234
    prius1234 New Member
    toronto
    2003 Prius
    Hallo
    Does anybody know where should I start to look for the problem?
    On the original scanner from toyoto I have code p3100 but under code
    is 310 "generator pwn line connection malfuncion"
    What PWN stands for?
    Thank you.
  2. Flying White Dutchman
    4,374
    313
    power?
  3. prius1234
    toronto
    2003 Prius
    I whould imgine that pwr should be short for power,
    but I am not shure.
    By the way this is prius 2003.
    Thank you.
  4. jdenenberg
    jdenenberg EE Professor
    3,911
    1,913
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If it was PWM it would stand for Pulse Width Modulator which is the method used to generate a variable DC voltage from the "Inverter".
    JeffD
  5. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    didn't see anything about pwn for that inf code- universal repair for that and a handful of other inf codes is to replace hv ecu.
  6. prius1234
    toronto
    2003 Prius
    Thank you
    I think I found the problem The bottom of the inverter
    is broken and the board inside is demaged.
    Thank you again.
  7. Flying White Dutchman
    4,374
    313
    broken?
    is it a salvaged prius
