Get Pumped!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hobbit, Jul 8, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    If you are still unconvinced that Toyota's recommended tire pressure
    is completely, utterly WRONG, take a look RIGHT NOW at this:
    ... http://techno-fandom.org/~hobbit/cars/treadwear.jpg ...
    which is what happens when the center of the tread spends all its
    life NOT bearing its designed load.
    This isn't *my* wheel. I ran into another Prius owner today and we
    got to chatting, and I noticed that his tires looked BALD. He
    obligingly turned out the front wheel and we both got pictures of
    it -- he had never actually noticed. He had 35 psi in this
    particular front tire, but said that chances were good that they
    had been run lower than that sometimes.
    He's probably going to swap into a set of Hydroedges before winter.
    _H*
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    how many miles hobbit?
  3. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    You have me convinced. But I had been using 40 front and 38 rear. I think I am going to go 42 front and 40 rear from now on.
  4. efusco
    19,891
    1,194
    Nixa, MO
    looks like he's been a bit tough on that car too.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(efusco @ Jul 8 2006, 08:24 PM) [snapback]283201[/snapback]</div>
    you noticed the rocker panel also. Hard cornering will scuff them like that also but 35 is too low on a Prius. Wonder if he ever rotated them as well.
  6. saechaka
    saechaka Member
    225
    <div class='quotetop'>QUOTE(hobbit @ Jul 8 2006, 10:10 PM) [snapback]283195[/snapback]</div>
    mine was close to looking like those and i had kept mine at 42/40. i should've took some pics before i replaced them.
