Getting a constant ‘grinding’ noise during sweepers
Discussion in 'Gen 3 Prius Technical Discussion' started by Zradub, Sep 12, 2022.
  1. Zradub
    Zradub Junior Member
    40
    I’m getting a constant ‘grinding’ noise from the front end going around sweepers and some excessive tire wear in the front. Wheel bearings shot? Thanks.
  2. Tombukt2
    Tombukt2 Senior Member
    11,631
    2,059
    Durham NC
    Wheel bearing lower ball joint upper strut mounts if any of that is really sloppy you can get grinding grating in general noises that might make you stop driving
  3. Zradub
    40
    Thank you. Any idea of rough cost to get the bearings or lower ball joints replaced by a decent priced Indy?
    50,833
    $4-600.
  5. PriusCamper
    PriusCamper Senior Member
    11,873
    4,817
    Pacific Northwest, USA
    What is a sweeper? And how do you go around one?
