1. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    The oddest thing happened this morning on the way to work. Around 6:15 the radio turned on by itself! And no, I didn't press the mode button on the steering wheel, nor the power button on the radio. And nothing would have bumped either control. So do I have a haunted car?
    If it doesn't happen again, I'll chalk it up to the stray gamma ray striking the electronics, but if anyone has a better suggestion, well let's hear it.
    Thanks,
    Shawn
  2. orionll
    orionll Active Member
    1,115
    Do you seriously believe in ghosts? My theroy is that your machine was faulty or some way the sensor registered a press on the button from a manufacturing defect.
    P.S. Was anyone else in the Prius when this happened? Look again if the radio just turns on at about 6:15. Maybe if it does you can bring it to your dealer and ask them to check it out but they probably wouldnt want to do that because they probably do no have the time.
  3. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(TucsonPrius @ Nov 27 2006, 08:34 PM) [snapback]354672[/snapback]</div>
    You say that with such certainty. How can you be sure? Were your hands not on the wheel? :lol:
  4. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Radio cutting on and off was part of my MFD failure. As I drove around, sometimes both the radio and the MFD would die, then both would come back, then mostly the MFD would die again.
    Maybe this doesn't apply to you, but now you know...
  5. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Beware... they're all around us....
  6. klevitsky
    klevitsky Junior Member
    34
    My wife drives our Prius to work and she reported that once, while playing an MP3 CD, there was a loud blip through the speakers and the music stopped. When she pressed the Audio button to see what's going on, the first odd thing was that she heard a beep on the button press (we have it set to OFF). She found that all the FM presets were erased and the system beep had turned back on. As far as we could tell, the Audio portion of the MFD had effectively reverted to factory settings. None of the other screens were affected (Consumption did not reset, etc). Here's hoping that it was a one time freak occurrence and not a symptom of a larger MFD problem.
  7. eagle33199
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(klevitsky @ Nov 28 2006, 10:28 AM) [snapback]354798[/snapback]</div>
    Well, the audio is physically separate from the MFD - the part with the knobs, CD slot, etc is a different box from the display. I'm not positive where the settings are stored, but i believe the radio presets and a few other things (like that beep) are stored in the radio, not the MFD. it's possible there's a loose wire that goes into the MFD and she hit a bump or something that happened to jiggle it just right to cut power to the radio for a second - thus erasing the presets.
  8. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    <div class='quotetop'>QUOTE(mikepaul @ Nov 28 2006, 08:21 AM) [snapback]354750[/snapback]</div>
    Hm. I think I'd prefer the ghosts to the MFD failure. (And I'd really prefer just a weird one time event).
    Did your MFD failure (or any other failures) start out gradually and get worse, or was it a sudden event?
    Thanks,
    Shawn
  9. Cheap!
    Cheap! New Member
    1,157
    So sorry, I was playing with my inter-dimensional Prius time portal and I think it may have turned on your radio by accident..
    If it happens again take apart you dash and check all the connectors. This is easer then it sounds.
  10. carlisle
    carlisle New Member
    Those 04 models are known for AFD troubles. It is pretty expensive so I bet you'll opt to the possibility of gremlins in the car instead. :rolleyes:
  11. chimohio
    chimohio New Member
    460
    It's gotta be ghosts related to the Prius. If you re-arrange the word Prius you get Supir which stands fora communications system and broadcast IR network link . It's all in the letters. (Bart-Massey.com)
  12. Cheap!
    Cheap! New Member
    1,157
    Lets call TAPS.
  13. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(Mr. Zorg @ Nov 28 2006, 12:45 AM) [snapback]354731[/snapback]</div>
    OK, I retract this statement. Although I suppose I can't be sure I didn't hit the button by accident, the radio came on automatically for me too today on my way to lunch. Definitely odd.
  14. mikepaul
    1,763
    Columbia, SC
    <div class='quotetop'>QUOTE(TucsonPrius @ Nov 28 2006, 08:04 PM) [snapback]355056[/snapback]</div>
    There's always a chance that a previous one-time freeze-up of the radio controls was the beginning of the MFD failure, but until the display actually failed to show anything there were no real signs of trouble with it.
    As long as you have a display that toggles between Energy and Consumption just by pressing the Info button on the steering wheel, you're OK since that's the 'replacement' unit that should not up and die. Anything else, and just keep your fingers crossed...
