Glovebox light stays on when headlights are on
Discussion in 'Gen 2 Prius Main Forum' started by ucsbgaucho, Feb 7, 2007.
  1. ucsbgaucho
    ucsbgaucho New Member
    34
    Just as the subject says, is the glovebox light supposed to come on and stay on all the time when the headlights are on, even if the glovebox is closed? I know the standard is for the light to come on when the glovebox is opened, but I noticed a faint glow coming from the opening the other night, and realized mine just stays on.
  2. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Yes, that's the way it works. Apparently, it's cheaper to let it glow than put in a switch that would need fixing. Have you checked the fridge? :)
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< There are numerous previous comments regarding the lower Glove Box light.
    When I first began to post questions on PriusChat, I, too, asked questions which had been answered numerous times before. That gave me a good lesson: Use the "Search" feature and explore posts for at least several weeks prior to asking a question which has been answered. I suppose I am a slow learner :D
  4. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Yes, that's normal
    What would be abnormal is if your Glove Box Light went off when you turned your headlights off :)
  5. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(hyo silver @ Feb 7 2007, 06:55 PM) [snapback]386630[/snapback]</div>
    It's not cheaper to repair a switch, it's cheaper to NOT have the switch to begin with. But how much can a glove box switch add to cost of the vehicle? Pretty lame in my opinion of Toyota.
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(Tempus @ Feb 7 2007, 04:18 PM) [snapback]386698[/snapback]</div>
    yes THAT would be abnormal. and thank goodness your Prius is normal. iow, the glovebox light is on ALL the time. headlights or not
  7. ltu1542hvy
    ltu1542hvy New Member
    338
    Cotonou, Benin
    When I had my Prius I found that if I rearranged the contents of my lower glovebox so that something black was on top, the light wouldn't reflect out of the cracks around the glove box door. If I had a white sheet of paper on top, the light reflected back would be pretty noticeable. Try rearranging the stuff in your glovebox some late evening and see what happens.
    - Bill
  8. Tempus
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(ltu1542hvy @ Feb 8 2007, 10:25 AM) [snapback]386925[/snapback]</div>
    Or, just tell your passengers that's where the Nuclear Reactor is kept :)
