GM goes w/ 1.4L 4-cylinder ICE for Range Extender
Discussion in 'Chevrolet Volt' started by efusco, Jul 27, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
  2. bac
    bac Active Member
    863
    52
    Pennsylvania
    GM ...................... yawn. :rolleyes:
    ... Brad
  3. rfruth
    rfruth Member
    394
    Houston, Tx
    1.4L NA four also more reliable than 1.0L turbo ?
  4. bac
    bac Active Member
    863
    52
    Pennsylvania
    That is certainly possible.
    Sadly, and the end of the day .... it's still going to be a GM.
    ... Brad
  5. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I call BS.
    I believe that the 1.4L 4-cylinder was chosen over a 3 cylinder because the 1.4L is going to GM's new world engine for small cars. They have announced that 1.4L will be used in the new Chevy Cruze, which will be GM's world small platform. The 1.4L will be available in multiple outputs and in both NA and turbocharged forms.
    The Volt is already going be be expensive enough without using a low volume engine just for the Volt.
  6. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The reason to have a larger ICE is to down size the battery pack to hit the price point.
    This means the EV range will be reduced and compensated by running in series hybrid mode,
    which is less FE than parallel mode.
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    For the record, does anyone have the ORIGINAL specifications for the Volt: range, engine, price, etc. We should capture that for comparison later.
    Make sure you provide links for verification.
