Good video for running cable from dash to the trunk?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Juan Ramirez, Feb 13, 2025.
  1. Juan Ramirez
    Juan Ramirez Junior Member
    Fullerton, CA
    I installed my sub 5-6 years ago. I just replaced it with a sub that also has a remote knob that I want to install. Problem is I forgot how to remove the various panels that run across the side. I am thinking of running up the drivers side since it seems like to shortest route to a blank panel right under the power knob. Assuming it is best to go that side but let me know if it isn't.
    Anyway, I certain I used a video with instructions on removing the panels but for the life of me, I can locate it. It's been awhile so who knows.
    If anyone know of one I can use I would greatly appreciate. Thanks.
  2. amarino
    amarino Active Member
    134
    102
    99
    I ran my dashcam wire down the drivers side along the floor. It was really easy and this video pretty much shows the process. It shows the passenger side but it's the same on the drivers side:
    The door sill and B pillar trims pretty much snap off. However the front bottom curve next to where your left foot rests does have a plastic screw if you want to take that panel off. Also the rear seat side piece (that doesn't fold down) has a bolt that you also need to remove, then it slides up.
    #2 amarino, Feb 19, 2025
    Xterra72 and Brian1954 like this.
