Greddy Informeter Touch OBD Meter
Discussion in 'Gen 3 Prius Accessories and Modifications' started by robby3, Apr 25, 2011.
  1. robby3
    robby3 Member
    181
    24
    Switzerland
    This is the first modification I start with my Prius. More and more parts are on their way as the Prius will become a promotional car for the parts I'm selling on my european car tuning shop.
    The GREDDY Informeter Touch is a nice 3.5" display unit that directly plugs into the OBD port of your Prius (any year). The unit also comes with an adjustable stand and cig.ligher cable. Later is not necessary as you can power the Informeter also via the OBD port. But if you want to fully diconnect it from power souce when the car is off too then use the cig ligher cable. Otherwise it draws around 40mA in standby, Not a deal but if the car is not used for weeks in can drain the batt. The Informeter Touch has a touchscreen where all settings and controls are selected with your fingertip.
    Link to the product page:
    GReddy
    Installation: Nothing easier than that. Plug the OBD plug into the port and run the wires somewhere behind the steering column (depends on the desired location). Duration: 2 minutes
    The display/headunit can be mounted where you like. I have placed the stand onto the steering column and selected the horizontal view of the values.
    Nice and small display/headunit with chrome frame.
    After startup the unit must be configured for the Prius. In the car maker section are 4 Toyota protocols, but the Prius III is using the standard ISO-CAN bus. This must be selected so the unit can communicate with the car.
    This is how the installed Greddy Informeter touch looks like with 4 values displaying at once (rpm, water temp, horsepower, intake temp, all values are metric in my case)
    The display can show several measures at the same time, depending on if you just want to see the numbers or also graphic bars or circle or needle meter combined together others.
    The chart below shows the values that the ISO-CAN Protocol delivers for the Prius III. The values that can be metered on our cars are:
    -rpm, speed, timing, throttle voltage, throttle %
    - water temp, intake air temp, intake air pressure (vakuum, no sense on the Prius)
    - airflow g/s, airflow %
    - gear position (no sense on Prius)
    - horsepower (calculated from weight, size, acceleration), trip
    - fuelsystem (A/F situation feedback control)
    - primary and secondary O2 sensor voltage
    - battery voltage
    Some more or less documented features of the Greddy Informeter Touch are:
    - Max and min value warning (buzzer and flash)
    - peak hold (the small amber line on the scales)
    - on a bar-graph the color of the segments are changing the higher the value is. e.g. water is blue when cold (17°C) and becomes more and more green (36°C).
    Power measure: I have not yet tried this feature although it works like all other do (Apexi, HKS, etc.) I do not expect wonders especially due to the fact that it lacks of an accelometer or any G-sensor. So if one adjusts the weight and car/engine type until he's getting the promised hp then it's a good start for any mods (i.e. intake, exhaust). This works as our experiences with such type of hp measurement showed 7hp average for a K&N intake system on an MR-S after about 5 test-runs. I will post results everytime when a particular modification has been installed on the car.
    Enjoy :)
    3 people like this.
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Good information, nice pictures and write up. Mahalo.
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    How about HV battery information, such as SOC, volts, amperes, temperatures and others?
    Ken@Japan
  4. robby3
    robby3 Member
    181
    24
    Switzerland
    These informations are not part of fhe standard ISO-CAN protocol. I don't know if other universal OBD meters/displays can show these. I've seen no more information on Scangauge as one example.
  5. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    Scangauge has a special feature called XGAUGE.
    Ken@Japan
  6. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Over $400. Ouch!
  7. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Finally something that isn't an eyesore like the scanguage.
  8. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    That's what I was thinking also...
    Posted from my iPhone via the Tapatalk app.
  9. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    There are other solutions. This is an app called Torque I have on my Android phone.
