Handicap Equipping a 2001 Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Dragonfly2009, Apr 3, 2009.
  1. Dragonfly2009
    Dragonfly2009 New Member
    I am thinking about buying a 2001 Prius. However, in the probably near future I will need to handicap equip the car. Notably power assisted braking (I'm not sure if that is the correct terminology). To make the brake pedal lighter to use. Is this possible in a 2001 Prius? I know the Prius brakes partly on its electric motor so I wonder if it is possible to strengthen the hydraulic braking without upsetting the balance between braking on the engine and braking hydraulically.
    Is the 2001 Prius already drive by wire?
    Is there space somewhere, like behind the bumper, for a vacuum pump?
    Looking for answers....
    I have a modification company looking into this for me but they can't give me an answer soon.
  2. tochatihu
    tochatihu Senior Member
    9,474
    3,657
    Kunming Yunnan China
    2001 Prius
    Welcome 1st time poster! Toyota has a program about this:
    Toyota Mobility
    and you should find out what they might do to help you.
    Please post again on how it goes. Good luck
  3. Dragonfly2009
    I live in The Netherlands. The requirement to drive a car is that you can deliver 600 N (60 kg) of pressure on the brake pedal. This is to be sure that you can stop the car in case the hydraulic brake system fails.
    Now my question: what will happen if the hydraulic brake system fails in a Prius model 2001? Will the force needed on the brake pedal to stop the car increase or not?
