Hard Knocks- already replaced everything
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Babybird125, Sep 17, 2025 at 1:44 PM.
  1. Babybird125
    Babybird125 New Member
    Yesterday
    Nc
    So car was knocking on startup. It has 190k on it so figured we would replace spark plugs. Still bad... replaced injectors... even worse...
    Replaced egr and cleaned out canister... even worse... drained gas and put in new just in case...
    Checked everything I can think of at this point any ideas?
    Codes are for cylender misfires
  2. Tombukt2
    Tombukt2 Senior Member
    12,656
    2,253
    Durham NC
    Head gasket buddy this engine is known for it. Much documentation here
  3. Mendel Leisk
    40,934
    A couple of head gasket links in my signature (on a phone turn it landscape to see signatures).
    Just curious: what do you mean by this, the evaporation charcoal canister?
  4. ASRDogman
    ASRDogman Senior Member
    7,405
    3,859
    And how much is the price of rice in china????
    It is likely you have a damaged head gasket.
    Are you loosing coolant? Have you done a coolant pressure test and use a bore scope to
    looked into the cylinders for coolant leaking between cylinders?
    Most likely between #'s 1 and 2.
