Has anybody heard of this "necessary" service??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prplrain68, Oct 19, 2009.
  1. prplrain68
    prplrain68 New Member
    San Pedro, CA
    I just recently had my 75K service performed and thought everything was ok. To date, my Prius has not given me any problems (other than her aux battery dying and needing a minor replacement). Well, the service manager needed to talk to me, after completing my maintenance. He said my car was in need of a EFI W/Throttle body service (210$) and service Mass Air Flow Sensor (115$). These prices are a bit steep for me and I don't know how necessary they really are. Naturally, I don't know much that actually happens (under the hood) nor which maintenance is truly necessary or not. The manager did advise me to complete these immediately. He said the sensor was clogged/dirty and it could deem both items inoperable. He said if the sensor BREAKS, it will cost 600$ to replace! Of course, if this is all true, I don't want it to get to that point. I asked him when I need to come up with money and when it absolutely has to be done. He shrugged his shoulders and told me: "eh, as long as it's before your next maintenance you should be fine". EEK!
    My question to all you beautiful Prii owners is if you've not only heard of this scenario, but if it's truly all "necessarY" (as he states it is). Please let me know asap. Thank you for all your support!!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    It may be...but you may be able to do it yourself. Don't know what an EFI is though...
    100K maint - 2
  3. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    EFI is electronic fuel injection. I strongly suspect the $210 service is pouring a $15 bottle of injector cleaner into the tank.
  4. efusco
    19,891
    1,194
    Nixa, MO
    Oh, I bet you're right. I'd definately skip that unless they can prove the injectors are bad/dirty/clogged. From Hobbit's link I provided above:
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Throttle body problems on the 2001 to 2003 Classic Gen I Prius were common, they seem less common on 2004 to 2009 iconic Gen II Prius.
    Here is a page showing how to do exactly what your dealer wants $210 for. The example car is a Gen I but the Gen II is similar.
    Cleaning Prius Throttle
    Edit: efusco has gen II pictures, perhaps looking at both will help
    I think the $210 dollar service in what I am linking on a Gen I, and the $115 is the part is efusco's link where they pop out and clean the air flow sensor.
  6. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    If they're doing it properly they should be cleaning the throttle body as well as using a can of Toyota fuel injector cleaner which they will hook directly to your fuel rail and the car will run on this solution until the can is empty. If this is not what you're getting for that price then do not have it done.
  7. prplrain68
    San Pedro, CA
    Thank you everyone for your help!! I am gonna take a look under the hood and see if it makes sense (after seeing the step by step pictures). If I do try and perform these steps..do you think i risk any chance of harming my dear prius? What about voiding my extended warranty? Just curious. Again..thank you.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    How about dumping a can of fuel injector cleaner into the fuel tank on the next fill-up and calling it a day for the fuel injector ? Cleaning the air throttle looks straightforward from BWilson's pictures.
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    avoid EFI services unless your engine is misfiring.
  10. richard schumacher
    7,664
    1,042
    United States
    If you buy gas with ethanol in it (and in San Pedro it would be hard not to) your car is getting all the injector cleaner it needs.
    The sensor and throttle plate may indeed need cleaning, especially if the oil is chronically overfilled. Do you ever check the oil level yourself? What is it now?
