Has anyone have an ansewer?
Discussion in 'Gen 3 Prius Technical Discussion' started by nick6063, Jun 17, 2011.
  1. nick6063
    nick6063 Junior Member
    16
    17
    Kalamazoo, MI
    When switching on the outside air intake and also depressing the front windsheild switch, I experience the air from the vents to be unusally cold. Promptimg me to believe the air conditioner is activated even tho the AC light is not on. I mentioned this to the service department at my local Toyota dealership and the service guy said that the defrost switch activates the condenser. I must also add that the setting for temp is set to Lo and the Auto switch is not on. Has anyone experienced this? Is the sevice guy correct? I hesitate to believe he is correct. Thanks, Nick
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I think I HAS an answer for you- It sounds like your fan is on and nothing else.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Most if not all cars these days activate the ac to dehumidify when defrost is selected.
  4. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    But, when the A/C turns on, doesn't the A/C light also turn on?
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    As per page 274 of the Owner's Manual:
    Press (the front defrost button). The air conditioning system control operates automatically. Recirculated air mode will automatically switch to the outside air mode.
    Also mentions automatically on page 278 when in cold weather and the use of defrost.
    From what I understand, by pressing the A/C button (indicator on) it forces the use of the air condition but otherwise it is up to the ECUs (in auto) to determine its use (without the indicator coming on).
  6. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    I think spiderman is almost right.
    Front defrost on: A/C will run automatically - most likely on, since if you're trying to defog, that means the humidity is high, and the car has a humidity sensor.
    Front defrost off, A/C light on: A/C will run automatically when needed, depending on the humidity and temperature. If you're heating in the winter, for example, I don't believe the A/C will typically come on.
    Front defrost off, A/C light off: A/C will not run.
  7. Tideland Prius
    16,559
    Oh and just to add to all the responses here,
    because you were in LO, when you activated the front defroster, essentially it's MAX COLD with A/C blowing at the windshield. The defroster will remember your temperature setting.
