Has anyone used their headlight washers?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Joyce, Oct 7, 2012.
  1. Joyce
    Joyce Junior Member
    40
    South of Boston
    Our salesman showed us the headlight washers, and we all saw how it sprayed not only the headlights, but the hood too! Then, everything was covered with soapy water that just sat there.
    Has anyone been successful with the washer?
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    If you have your headlights on and you wash your windshield you will also wash your headlights by default, unless you pull the circuit beaker or disable via other means. I don't use mine by pressing the actual headlight washer button, but they will occasionally get used as mentioned above. I have not disabled mine some members here have.
    Posted from my iPhone via the Tapatalk app.
  3. Joyce
    Joyce Junior Member
    40
    South of Boston
    I'm getting my PIP today so I was unaware of just how it works. Thanks for the info.
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    That is how it works on my car you PiP might be the same or slightly different, I would think the same though. Check your owners manual or just give it a try.
  5. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    That's not how it works for the plug-in.
    The windshield squirter is seperate from the headlights.
    Here in Minnesota during the winter, where everything gets covered in grime while you drive anyway, having that feature should prove very handy.
  6. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    That is why I said this after (see below). It is separate on my car also I have a button on the left side of the console for headlight washing. On my car (your PiP's may be different) if you have your headlights on and you wash your windshield by using the windshield washer on the stalk the headlight washers will also activate washing your headlights at the same time as your window.
    John,
    Have you tried to use your windshield washer with your headlights on before?
  7. rockfeller
    rockfeller Junior Member
    88
    CA
    I have not seen head light washer in my basic PiP.
  8. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    It is only on the Advanced. I have not been able to determine any actual use for the washers.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    They do come in handy in the snow/ice, but also while driving and you notice a large bug shaped dim in your headlamp beam pattern. I don't have them on the Prius, but on the Lexus RX they work well.
    The best system I have seen though was on a Mercedes (I think) where it had heated/steamed sprayers. That really helps with the snow ice. If I had them on the Prius, I would probably add an aftermarket conversion to electrically boil the washer fluid right before shooting it at the lens.
  10. brighamwj
    brighamwj Member
    120
    Costa Mesa, CA
    Unless they salt the heck out of your roads or your drive on unpaved often, I am not sure the purpose. Sounds like a pricey add on for an easy clean job. I am in the market for a PIP and that seemed like the least usefull advanced package feature and I have lived in MI and UT where salt is a way of life.
  11. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Yup, that about explains how they work(ed) on both my 2010 and current 2012 pip.
  12. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    For my 2010, the washers are automatically activated the first time you use the windshield wipers IF you already have the headlamps turned on.
  13. CharlesH
    2,790
    1,153
    Roseville, CA
    Just a tidbit of information for those folks who live where there are REAL winters, salting roads is not permitted in California, even in the Sierra mountains which have serious snow. The issue is not the corrosion damage; it is an (surprise!) environmental issue.
  14. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    And that, unfortunately, has not changed for 2012.
  15. john1701a
    12,793
    5,275
    57
    There hasn't been a need at night yet. And I use the driving lights rather than the headlights during the day, which don't trigger the headlight squirter.
    The lights still get very dirty, very quickly. Here in the land of glacial deposits, we use lots of sand to deal with slippery roads, not just salt.
