Hatch opening lift has become gummy. What to do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KansasPrius, Aug 25, 2018.
  1. KansasPrius
    KansasPrius Hybrid Advocate
    Kansas City metro
    When I open the back hatch I get sticky goo on my hand. My car is a 2007. I have always had it in my garage when at home. What do I do? Is this a part that is simple to replace? Has anyone else had this problem? If so, how did you solve/fix it?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Trunk Hatch Liftgate Switch Latch Release Button Rubber Cover Replacement Toyota | eBay
    When I bought my 2007 about 18 months ago, it had this problem. Very gooey. The correct way to replace this is to remove the switch, which requires taking off the hatch inside cover.
    To remove the gooey stuff that had gotten into the switch, I used a can of AutoZone brake cleaner , an old toothbrush and a very small screwdriver to scrape it out. Maybe yours isn't as bad as mine was.
  3. PriusCamper
    PriusCamper Senior Member
    11,869
    4,814
    Pacific Northwest, USA
    yep... something about the type of material they decided to use, combined with how weather, exhaust and dust accumulates there is what causes that. It's an easy fix though... Find a relatively thick chunk of rubber or similar material, remove the old one and traces the shape on to the new material, cut it out and screw it in place and you're done! Super easy! Maybe I should finally get around to doing it on my '07? Thanks for the reminder.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Might have better luck in the actual Prius thread...
    That being said, rubbing alcohol to the rubber weatherstripping could clean them up and "release" some of the stick.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    Is this really a C ??
    That's an area that never gets cleaned really good with a routine car wash.
    I would strongly recommend alcohol and a RAG (not paper towel) and a good rub......or two......on that rubber cover before considering replacing any parts. While you are at it, clean the other parts under that lip too. It might be REALLY cruddy.
    If that seems to clear it up, a coating of silicone spray lube (which dries dry but slippery) should help delay a re-occurrence.
  6. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Her car is a 2007 Prius, not a C model. This is not merely a layer of stickiness on the rubber. This is a true degradation/devulcanizing on the rubber full thickness. No amount of cleaning is going to solve this issue, unless it's cleaned to the extent it's completely removed.
    PriusCamper likes this.
